'85 K20 350ci died out on the road not getting fuel to carb, replaced fuel pump and now not getting fuel to pump
klarster
Nebraska
Zac
Best way to clean off the sock then would be an air enema into the main line to blast that crap off of there? Or would it be best to drop the tank, remove sender and clean manually?
klarster
Nebraska
Zac
In that case I sure am glad I got the Delphi, no idea what was in there before...
Blasting it with air will likely just blow the sock completely off, which will let it work initially but will also allow the pump to suck up a bunch of junk. If it is bad enough in the tank to plug up the sock, it is worth dropping the tank and replacing the sock while cleaning out the tank as well. Replace all the rubber fuel line above the tank while you are at it. It could also be a bad rubber hose or a bad switching valve that is not allowing fuel to get pulled through the sender.
klarster
Nebraska
Zac
I'll be dropping the tank Saturday most likely, looks like that'll be the warmest day this week. Will be updating on what I find!
klarster
Nebraska
Zac
Update/Conclusion! Dropped the tank Saturday and found ALL THE CRUD. Looks like when previous owner replaced the sending unit he had tunnel vision and just wanted to get to the task at hand. Sediment galore. Ended up doing a complete empty and clean job, and replaced all the fuel lines while I was at it. Sucker's back on the road again with that intoxicating true-dual 350 cackle! Many, many thanks to those who helped lend their knowledge, experience and suggestions to get me back rolling again!
klarster
Nebraska
Zac
An excellent point. Good thing I know where to come next time I get in a tough spot!
Ahebert
