85chevc30cummins
Kel
c30
3 out of 4 blades on the trans cooler, just discovered after pulling condenser out.. sweeet
85chevc30cummins
Kel
c30
Decided to not run the fan on the trans cooler since it’s getting electric fans on the radiator. I’ve cleaned up the firewall, and the hvac and I’m going to use butyl rubber to put the boxes back together. Also fitting an updated condenser. I need to find a way to mount the new radiator higher.
85chevc30cummins
Kel
c30
Slapped on some simulators
grampsbutler
San Diego, CA
Graham
K10 Suburban
6.2l Diesel
What did you do for your radiator and ac condenser? I am doing a similar build (6.7 in an 84 Suburban) and I'd love to know what you went with and any challenges you ran into.
Obullard74
