Ronno6
- May 14, 2018
- South Mississippi
- Ron
- C10
I purchased a tilt column for my 84 C10.
When I received it, the shaft is pushed up into the bottom of the housing be over an inch...
the hole for the cross bolt in inside the bearing at the bottom- not how it was pictured.
Apparently the whole shebang has moved upwards inside the housing.
Is this a simple fox, or will I get an education on the disassembly of the tilt column?
However, the lock plate appears to be a bit higher than usual, but not THAT much....
Last photo is not mine,,,,included for reference
Top pic is from the original listing (if it is in order, that is.....)
