84 Chevy P30??? Anyone know anything??
Rusty Nail
Rusty
350sbc
The clutch is backwards?
I don't think a t-56 is gonna play well with BBC torque, but good luck trying!
Bennyt
Surprise
Ben
The current T56 is rated for 700 foot pounds of torque in stock form. Pretty sure that covers 99% of the BBC out there. There are companies that bring that up to 1000+ ft lbs as well.
Most of the TT guys with 1500-2000hp run T56's. If you aren't doing heavy launches, it will live forever.
Quicktime makes a bellhousing and plenty of clutch/ flywheel kits out there.
Also, this revived thread is 4 years old so I hope the OP figured it out by now.
The LT1 style clutch was a pull type rather than push type, but that's no big deal. The hydraulic slave is activated the same way as anything else. It takes a special flywheel, that was only used behind behind a neutral balance small block with 1-piece rear main. Aftermarket flywheels are available to run it behind an older SBC/BBC, neutral balance or weighted.
Even the earlier (and weaker) models are capable of handling the torque of a stock BBC in a street car or truck.
Auburn, Washington
Edit, nevermind.
Just noticed Rusty exhumed a 4 year old thread.....
78silverado
