82 K10 Steering Problem
Chief4451
Nebraska
Wes
I have a 82 K10 with a 4 inch rough country lift and 33x12.50"tires. When I was adjusting my drag link to straighten my steering wheel. I noticed when I turned the wheel the pitman arm would raise up and actually lift the truck a bit before it started turning the tires. What would cause that to happen? I didn't put the lift on this truck and I think it already has a raised steering arm. Another weird thing that happens is when you turn the steering wheel to the left and go back straight the steering wheel ends up a quarter turn off the left. Then turn to the right and it brings it back center, but if you turn right it makes it a quarter turn off to the right. Weirdest thing I have ever seen. Any clue why that might happen either? I appreciate any help in advance
highdesertrange
kalifornia
mike
k30
is your steering box loose? is your steering arm loose? is your frame cracked? do you have the correct steering arm? do you have a bad tie rod end? highdesertranger
Chief4451
Nebraska
Wes
The steering box and arm are tight and the frame is not cracked. I'm not sure how to tell if its the right steering arm or not. I will have to check on the tie rod end. Thanks for the tips
highdesertrange
kalifornia
mike
k30
can you post a pic? highdesertranger
crazy4offroad
Equal Opportunity Destroyer
West BY-GOD Virginia
K-10
350/SM465/NP205
Start the truck, reach through the fender well and turn the steering shaft right behind the steering box. If the box looks like it is moving around at all, more than likely the frame is cracked. I know you said yours wasn't, but I didn't think mine was either.
Camar068
Kentucky
10 yrs Air Force
Did you figure out why the pitman arm is raising? Mine is doing it to and I have slop with everything tight. I started a post and noticed this one afterwords, thought I'd ask.
highdesertrange
kalifornia
mike
k30
the drag link should basically be flat(parallel to the ground). if it's not you will have problems one of which is lifting the truck when you turn. this happen when the drag link is pointed down to the axle and you a standing still. it's less resistance to raise the truck a little then to turn the wheels. once the truck is moving this is lessened. however if your pitman arm is not flat you have issues. highdesertranger
ScreechPowers
