idahovette
- Aug 7, 2016
- Weiser Idaho
- Perry
- K20-K10
WTF what happened
Guessing frustration and anger for almost 2 yrs.Why?!!!
I read a quote the other day, "Your speed doesn't matter, forward is forward."
Looking good.
Also need advice on seam sealer, gonna need a 55 gallon drum LMAO. I'm thinking brush on for tight areas, where the metal is tight, and caulk gun style for the larger gaps? I was also thinking to do the chassis saver or epoxy first, seam seal, then go back over the sealer. I used weld thru primer on all overlapping joints, and I even hit the underside of the rear pan, front pan, inside the braces and torque box in chassis saver before hand.
