ih8vols
- Aug 31, 2019
- TN
- SC
- C10
- 2002 LS1 4.8
I just lowered the front 3” with drop spindles. When putting everything back together, the steel hose to the caliber had to be bent slightly to keep the rubber brake hose from running the caster nut on the spindle. This is common when lowering from what I’ve read.
I never disconnected the brake line from the caliber while working on the spindles.
Once I got everything put back together, I started it up and had no brakes. The pedal went to the floor. Was never able to get any pressure. There’s no leaks. There was plenty of fluid in the MC.
The only thing I can think of is that I 1) pinched the brake like at the steel end or 2) somehow air got into the line.
Pictured below is the passenger side bend that I had to do. It doesn’t look bent enough to cause it to be pinched or anything.
Any ideas what might be the problem? I’m thinking of bleeding the brakes and seeing if that fixes it. Still trying to decide. Thanks!
