79 camaro
Swims350
Logan WV
none
love them keystone klassics kleedus, I need to find me some fender louvers like that for mine, I'vew got the 80/81 vents but like the louvers better
kleedus
wyo
Ray
1960 threw 91
c10 to k30
350 threw 454
mine is an original Z28 the only rust on it is the lower font fenders the quarters and underbody are rust free.
the interior is black but the carpet and door panels are gone and the seat frame on the driver side is broke.
I put a 400 horse 400 with a Muncie m-22 4 speed but I hate the 400(I don't like the way they run) and I got a borg warner super t-10 for it so I can put the Muncie in my chevelle.
so I am changing the 400/Muncie for a 350/super t10
Stewzer55
Ohio
Stew
R30
Chris, yours needs Keystones too.
kleedus
wyo
Ray
1960 threw 91
c10 to k30
350 threw 454
I also have a 73 Z28 with the same size cragar ss wheels on it
but I don't have any pictures of it.
Nasty-LSX
TogetherforeverCovid19
HOUSTON TX
Mi Hung Lo
c10/k10/k20
LSX
I love second gens!! heres my 70
dont mind the blue hose. it was temporary
Swims350
Logan WV
none
very nice!!
I've got 2 14 inch keystones on the front now, but no matches for rears, and one is wider then the other, out back is had low backspace 15x10 cragars ss but they were rough, chrome flaking and pitted so I painted them silver to use for rollers. Tires are shot, just junkers for rolling around.
I'm going to try and buy 2 cragar ss 10's for the back with the 4.25 or so backspace they come with and run 295/50's then up front not sure if I want 7 inch wides or 8's. I'm thinking 8's, match tire height to the rear or go shorter height but as wide as I can up front without mods to help handling.
Both my lower front fender has a couple spots, rest is ok minus that frame rail in back, interior all plastic is super brittle.
Driver4r
Nebraska
Trevor
k10,c20
Good looking marro, theres a few running around town localy. One was a 400 topped with an 8-71. And another is just a wee-O-5. The only problem I have with marros are that they are a unibody-spilt frame. Ive seen quite a few twist without connectors.
and btw, IM BACK XD
Swims350
Logan WV
none
here we go finally got pics...
I gotta organize before I can tear apart much more lol...
all the battery trey I had lol
That bumper cover was on the shelf for 2 days and last night decided to jump off and land on the fenders.
Swims350
Logan WV
none
round 2
Swims350
Logan WV
none
eeehhh I'm about to push this outside and use it's motor, trans and driveshaft to power my s10 and get it done.
PS front and middle has rot holes, ps rear has bad rust but no holes still solid, ds front same way solid but rusted bad, ds rear has some holes.
Swims350
Logan WV
none
fairly certain ps was from heater core it leaked on my headers when I installed them and you can see it's wet, it's been under the carport dry since june. not sure why the ds is bad, maybe the t-top leak without me seeing? maybe the windshield or cowl vents? I know the ds t-top outer seal leaked when washer down the outside of the driver's seat, but nothing anywhere else that I saw.
Time to figure it out and fix it.
Going to patch it up best as possible, or just install a new floor and be good for years to come?
Swims350
Logan WV
none
new pans FTW or nothing. I don't want to tear it down this far again in the next few years if I don't have to
Swims350
Logan WV
none
I am seriously thinking that I may clean up the drivetrain and some fresh gasket for the trans, and if the camaro driveshaft is the right length, swap it all in the s10. I just need brakes for it, a drivetrain, and then fuel lines/brake lines which are all cheap enough, tires is what will cost me and/or wheels.
IF I do that, the camaro will become the long term project, since I want to do new carpet, repair any rust, paint, everything new, seat upholstery etc. I can always build the 350 I have that's roller cam ready, just have to track down a short tail th350 for it, or find a long tail or 700r4 for the s10 an swap trans later.
CSFJ
A buddy of mine had a '74 with a very healthy 454 when we were in high school. Car was always a blast to ride in. For me, the late 70's versions are what always come to mind when someone says camaro. They're definitely on the short list of cars I would consider owning. Maybe someday.
AWBLAIR
