Instigate
- Sep 17, 2012
- Vista, CA
- Joe
- 350ci 5.7L
I'm mounting the Spectra Fuel Tank "Part Number: SPIGM15A Manufacturer Number: GM15A" And using the straps that goes with it "ST12". I got the parts from autopartswarehouse.com, Which I don't recommend. They outsource their customer service to India and they are not knowledgeable about the parts at all. The guy was ready to let me order to complete wrong part when I was on the phone with him. Anyways, I'm just wondering if anyone had dealt with this tank before and might have some pictures of it mounted. I had to remove a support beam and I'm going to have to relocate a bracket that holds the rear brake hose and chop off part of the stock exhaust, which I don't really mind because it gives me an excuse to maybe buy a new muffler and tip.
It's a 79 GMC pickup 1 ton that I swapped the bed with a service bed, so I had to loose the dual gas tanks that mounted on the outside of the frame. I ended up putting a fuel cell in a knack tool box I mounted in the back but I'm going to have to pass smog eventually so I bought a tank I can hook up the filler neck and gas cap to. I would like to see any pictures anyone might have of similar setups with the tank mounted behind the rear axle using a strap setup like what I have going on.
This is the Tank:
These are the straps:
This is the Tank:
