'76 with stock 12 bolt question
Cragmor
Iowa
My truck has what appears to be the stock 12 bolt, and most likely no modifications. Is this worth beefing up, or should I look to replace the entire thing? I read that for some reason the truck 12 bolts are weaker than the car 12 bolts. Any truth to this? Also, with the stock diff, what is my realistic power limitation? I hope to put in a new engine, transmission, beef up/replace diff and driveshaft in one motion, but lacking that, I just want to know how I need to baby what is there.
NickTransmissions
Las Vegas
Nick
You'd need to tell us how much power the engine will be making (ballpark) and how you plan to use the vehicle. If power goes way up, Id go to a 14 bolt FF....
What transmission will you be going with?
jstewart7501
