wanderinthru
- Jul 23, 2020
- Mid Point Route 66
- Shakey
- 81, 70, 75, 84, 89
- K 10, C 30, K 20
Is this truck a square?? Anyway, working on one that ain't working, have never worked on one before. Guess as these old things get older new older things go to breaking??
Found and repaired all the wiring from the gear shift switch to the firewall then back to the rear end. Have 12 volts back there, grounds are clean and grounding. Getting nothing out of the deally what changes the gears (possible wiring problem back in that itty bitty area where the wires disappear?) Ohm the wires going to that it bounces from 270 to 320.... green wire to ground ohms about 130?
My biggest questions are
1. is that deal a motor or solinoid?
2. any thing important going to fly out, fall down in the pumpkin when I take it off?
Thanks guys
Shakey
Thanks guys
Shakey
