74 C10 rear end interchange
oldearl
miserable valley
oldearl
C 10
350 CID
Hello All, it's been a while since I logged in here. Lots of great information when I use the search. All of your expertise is very much appreciated.
I am looking to find out what other square body year rear ends fit a 1974 C10 long bed ? Is it 73 to 79 without changing anything ?
It seems the poor old girl is asking for more money to be put into her.
The issue is when I put the auto transmission in gear she sorta locks up until I give her more throttle, it makes a popping noise then moves very slowly . I did jack up the rear so that the wheels were off the ground. I can spin both wheels with the trans in park.
Thanks in advance
Old Earl
Tonimus
Phoenix
Tony
C10 Suburban
If you're going like for like axle and doing the whole axle, I believe all the square body rear ends are set up the same.
75gmck25
Northern Virginia
Bruce
All of the 1/2 ton square-body rear axles should bolt right in, but the driveshaft yoke may be different. Not a problem if you have a local place that can change it if necessary.
Lancew
