73-80 vs 81-87 Parking Brake
Shields
Kelowna
Dayton
Hey everybody, I am wondering about the differences between the parking brake fittings at the drum on a 73-80 12 bolt and if they are compatible with a parking brake setup on a 81-87 cab/chassis. I swapped a 12 bolt from a 77' c10 into my 86' c10 and i want to know if my factory parking brake system will accommodate the earlier rear end. I don't have the cables otherwise I would just rig it up and know for myself, any input is appreciated thanks.
C10MixMaster
Kingman AZ
Ben
C10 BIG10
ZZ4 350
the hardware kits seem to interchange between those years 76-87 . so the backing plates are probably the same. take a good look at the backing plates if they match you should be good to go.
bluex
Spartanburg SC
C15
I put a 72 12 bolt in my 78 using the 78 brakes from the backing plates out and swapped to the 81+ cable setup at the same time. So the cables should go right in an connect just fine to the earlier rear axle.
I thought the cable setup changed in '83?
winfred
