72 Chevelle Build
Driver4r
Nebraska
Trevor
k10,c20
Well, I Figured I would make a build thread for the progress i make on my chevelle. In hopes of having it drivable/presentable my sr. year in HS, Im under somewhat of a tight deadline.
Current car specs:
350ci 4bbl.(matching #)
Th350
10bolt w/ 2.56 Posi.
Bench
Malibu tags
Ideas:
either a big sbc or a medium bbc
3.73-4.11
buckets
console w/ shifter
Welds w/ Big rubber
Ill get a pic up soon.
BTW: I thought I would add that its a heat only car, no A/C
In for some pics :popcorn:
Driver4r
Nebraska
Trevor
k10,c20
Ive posted a pic of it on here befor, look in the topic i started(pics of toys or something).
Are you going for a 12 bolt rear or sticking with the 10 bolt? IIRC, the 2.56 carrier won't work with any other gear sets.
Driver4r
Nebraska
Trevor
k10,c20
Really? This axle is the 8.2" ring and ive found a 4.11 8.2" set.
Yeah, my Impala also has the 8.2 with 2.56 gears and from what I remember the 2.56 ring has it's own carrier and you can't even buy aftermarket gears to fit that carrier. You need a carrier from like 3.08 and up to get the gears you want. I'm just going off my memory here, I decided just to go with a 12 bolt that won't end up broken anyway.
##After checking the Richmond listing in the Jeg's catalog, I was correct.##
Driver4r
Nebraska
Trevor
k10,c20
well..... ****, now i need a new posi then.
And dad wont let me use any of his 12 bolts.
Driver4r
Nebraska
Trevor
k10,c20
Im trying to figure out what i should do for trans/ rear gears.
Th350 w/ 4.11's is gonna rap really high at 60mpg
Anyone else wanna give some input?
I'm planning on something in the 3.31-3.55 range with a 275/60 tire on a 15x8 wheel.
Driver4r
Nebraska
Trevor
k10,c20
Im planning on running 295/50-15's on the back and 205's on the front(some short,skiney tire).
A calculator said with 4.11's and 27" tires ill run about 3.4k so i would be running about 3.75k
Driver4r
Nebraska
Trevor
k10,c20
Little bit of a tight budget, and im not to this step yet, But what are some ideas you guys have for engines, Ive been thinking 355,383,434,396,427,454,496,511.
Tight budget usually means a basic iron-headed 350.
Still don't see no pics. A good build thread ALWAYS needs pics of said build! :deal:
Brandon_l1000
Tennessee
Brandon
350/sm465/np205
I offically hate you that is my fav car ever made. ok... maybe i don't hate you but i'm damn sure jealous lol
dhamp
Atlanta Area, GA
Derek
R-10 Custom Deluxe
what kind of mph are you wanting out of your build? Depending on the block of your build, I'd stick to something like 3.31s or 3.42s or something. Running anything higher on an older (lower redline) engine setup and you'll just haul azz to around 95mph then top out. That's fine for a qtr mile car, but for a cruiser it'll just suck gas running 4.11s. Maybe if you converted to a 4spd it would do. As you said though, you're on a budget so I didn't figure that was an option. My mostly stock Chevelle BB runs 3.31s and it's running pretty high over 110mph. Still pulling, but I wouldn't keep it up there long.
ssxa
