700R4 Trans Cooling Lines options/recommendations?
BlazerBill
Billy
Chevy K5 Blazer
This post is now here in the proper automatic transmission category. I’ll try to delete it from the manual transmission category.
1983 K5/ SBC350/4wd: I’m installing a new 700R4 trans and I’m in need new transmission lines. I’ve read several previous posts with different opinions on which types of lines would be best to use. Some say to install entire length factory pre-bent style hard lines, some say to use flex lines or rubber hose on the ends of hard lines or in between sections of hard lines. What’s the consensus for the best lines (quality,brand,material), configuration and size (O.D., I.D.) and length (5’, 7’) to use? I provided photos of options for reference purposes. BTW, the engine and trans are currently out of the vehicle which will make hard lines easier to install before installing the eng/trans combo. Thanks everyone!
I just bend my own from steel tubing from the parts store,cheap,fast and easy,and it's how it was done out of the factory. My 1986 C10 still has the original unmolested lines,they don't leak,it's kinda like GM knew what they were doing.
PrairieDrifter
North Dakota
Mason
84,79,77,76,70,48
350, 350, 350, 350, 350, 350
I would run my own hardlines or like hydraulic crimp style hose, along the frame rail instead of along the engine pan rail. Don't run rubber hose and hardlines, doesn't last.
The advanced adapter hoses work good, they're just too long. I've got 35,000 on mine. Depends how you want it routed.
Old Guy Bill
KY
Bill
The hard lines from Inline Tube is what I used, they fit well. But I am working on just a frame no cab installed yet.
mrdap
USA
C/K_Lover
C20/K30/V15/V2500
Steel lines.
Factory replacement reproduction steel lines are going to be your easiest route.
If you have the skills and the tools you can bend your own as suggested.
I would avoid rubber hose myself.
timbritton
canada
Tim
1500sierra
I bent my own lines from steel coated lines. Patience and try using old ones as a pattern.
romeyrome
