hazardous
- Sep 24, 2024
- Wisconsin
- Mark
- K20
Lurked a little bit, first post here though. Have a project 85 K20 with a 700r4/np208/auto lockers(I know, probably the worst combo in the history of recorded squares) that refuses to shift into 4Lo. The shifter is all outta wack right now and my dad (who's owned 5 squares himself) says its an adjustment issue with the shifter, but that doesn't explain why the T-case won't shift into 4Lo. I've been running it in 4Hi (rear brakes aren't adjusted out right so the tires just spin in 2Hi, it shifts fine inbetween 2Hi and 4Hi) and I'll shift the transmission into neutral, then the T-Case into neutral, then when I attempt to shift into 4Lo it just grinds and won't go in, and if I attempt to shift back into 4Hi it grinds aswell. Only way to put it in 4Lo is to shift the truck off and shift it (same w/4Hi). I want to reuse this case when I swap in a 6.2/4l80e this winter because A) I like the shift pattern and B) one less thing to buy. So, anyone have any idea why this thing won't shift in 4Lo?
