700r4 install
richard
mi
richard
383 stroker
1981 c 10 short box would like to install 700 r4 to replace 350 what parts will I need. thank You
yevgenievich
Place
Name
Year
Model
Size
if long tail shaft 350 in there(should be), then 700r4 bolts in with cross member moving back. Only have to wire in lock up and get correct adapter for tv cable hook up
1987 GMC Jimmy
Automobile Hoarder
Mississippi
Jesse
V1500 Jimmy
Does the 350C vacuum circuit not work for the 700R4?
JoeR Jr
Stokesdale, NC
Joe
6.0/4L80E
A 700R4 has no vacuum modulator. Its sole source of engine load is the TV cable. You have to have one, and get it properly adjusted.
Joe
yevgenievich
Place
Name
Year
Model
Size
Joe
We a referring to vacuum control torque converter lockup circuit used on th350c and earlier 700r4
jlyon1006
