6.2 running poorly
ridenby
William
M1028
6.2L
Engine was running well. It hasaGM8 turbo on it( previous owner). Started blowing black smoke, then grey with a little white every now an then. Lost a lot of power, to the point it barely pulled itself. Boost gauge read vacuum. Changed turbo out Still blowing smoke-maybe not as black,still grey, some white. low on power. Not sure of next move. It starts very well. Idles smooth. Goes funky at throttle. Help?
RecklessWOT
New Hampshire
Kevin
V10 Suburban Silverado
6.2s aren't known to be the best diesels out there, my guess is it wasn't happy about the turbo.
How much boost were you running? White smoke is most likely coolant. Have you checked compression? I'm guessing something cracked, or a catastrophic gasket failure at the least
ridenby
William
M1028
6.2L
I have had the truck for 3 years. Ran well until just recently. Boost never went over 5psi. It starts very well.
Vbb199
B-rate Hillbilly Customs
Salisbury NC
Vince
89 Suburban R1500, 79 C10
Sounds like cooked head gasket or cracked head
Blue Ox
Turning Diesel Fuel Into Fun
LI-NY
Derek
MCMLXXXV
K20HD
6.2L
I hate to jump on the blown head gasket bandwagon, but it's a possibility. You should be able to get a test kit to check for exhaust gasses in the coolant.
It's also possible that pieces got into the engine when the turbo failed.
Itali83
Maine
Ben
K10, 'burban C10, Jimmy
It sounds to me like the turbo was never the issue and didn’t come apart. Therefore no pieces to go into the intake and damage anything
Anyone who knows 6.2’s and have started them know that if ANYTHING is wrong with them compression wise, fuel wise, or anything they won’t start. The barely want to start on a 60 degree day. (A little exaggerated but you get the idea)
white smoke on a diesel isn’t automatically coolant. If it smells sweet and you’re loosing coolant, odds are it’s coolant. But it’s starting fine so it’s not putting water in a cylinder from a cracked head or head gasket.
completely unburnt diesel fuel will smoke white. Either from no compression (doubt it with his case) or injection timing (see where I’m going here?) I don’t claim to be a master wiz on these fuel pumps, never actually had one of these apart in my hands, but there is a timing advance unit built into them and I’m wondering(betting) this is the cause of the problem.
if it starts fine, odds are all 8 have good compression(no catastrophic damage to bottom end). Loosing coolant( don’t know from description yet, but that’ll rule out head or gasket. As will the smooth start and no hydrolocking)
check these things out and report back.
Ben
MrMarty51
Eastern Montana
Martin
Prestone, engine coolant has changed formula over the last ten or twenty years. Unless the coolant has been in the engine for a very long time, it will not have that tell tale sweet smell to it.
The coolant had a sweet taste to it that animals just loved. They would lap that stuff up until there was none left then die a very slow and painful death.
The new green prestone now has a very bitter taste to it.
ridenby
William
M1028
6.2L
Went and pulled air filter off. Maybe a little less smoke. It is smoking at idle. Vac hoses and wires seem to be connected. Will get back to it later today.
Scott Delaney
Joliet
Scott
6.2L Detroit Diesel
Interested to hear an update on this.
Mojave_Muse
California
crystal
c10 Suburban
while i'm still learning diesel, white smoke makes me think you have steam in the system.
I hope it's not a Milkshake who brings all the boys to the yard situation.
what's your dip stick telling? Black as night or creamy goo?
MartinK5
