550HP and tire melting?
Kurt McBride
Lakeway, TX
Kurt
damn nvm the big block that is a hell of a deal.
515hp a tunnel ram intake on that will get you to 550 if you really want it.
515 is close enough imo lol.
Agree 515 is close enough...besides I think TRI is only for carb'd applications?
86Peter454
Missouri
C10 Scottsdale
oh i was under the impression you would be carb'd.
the engine you linked to looked like it had a carb on it i assumed you would be using that. they are usually dual carb as far as i know.
but i dont see why you couldnt use EFI with one. as long as its not direct port i dont see an issue. though they can be very tall and may need a hole in the hood.
damn it im rambling. just deal with 515 lol.
Kurt McBride
Lakeway, TX
Kurt
haha! no worries. Yeah, I am going to do FI Tech or similar for ease of starting and fuel mileage. I won't be cutting any holes in the hood, so, 515 it is with that engine.
shiftpro
BC Canada
shiftpro
350, 383, 454, 496!
A tunnel ram will kill your bottom end and idle... unless you run propane... which I always recommend because then you can build high compression and love life.
gpmorgan
Tupelo Ms.
greg
I have a fitech on a bbc. It didn't help with the "two words". It has killer throttle responce though.
Jrgunn5150
Questionable methods
Ionia Mi
J.R.
6.slow
You can do 550 on a junkyard 4.8, stone stock with a turbo, camshaft, and valvesprings.
gpmorgan
Tupelo Ms.
greg
The words "stone stock" are never in a hot rodders vocabulary. Lol.
Jrgunn5150
Ionia Mi
J.R.
6.slow
Anything else on an LS is a waste of money.
Cam, turbo, valvesprings, send it.
QBuff02
Central IL
Quincy
Nope damn 10 bucks a gallon, the smell accompanied by the sounds is enough to put you in sensory overload.
I run a blend of premium 93 octane and Sunoco Standard which if I remember correctly is 110 octane.. Do I need to? Not really, but it's a toy that doesn't get driven much and I like the way it smells. Plus it actually helped crisp up the throttle response on the 'ol BBC! And not in the "I can feel it made a difference" but in the actual "you can tell it made a difference" sense! Lol
pursleym9
