5 Pin Ignition Module / 1103465 HEI Distributor (for specific Electronic Spark Control Engines)
RanchWelder
Earth
Blazer
355ci
Here it is, with the Ignition Module:
Those of you using this very specific HEI unit, know what you are looking at.
Pay close attention to the weights pictured. Please confirm these are what you want before buying...
The unit was replaced, because the shop did not have time to disassemble and replace the broken YELLOW magneto coil wire... (Everybody throws away the good stuff). You will have to push the pin on the gear, and replace the magnetic coil.
The distributor pickup coil MAY use 3 pin LX343. $22.89, NOT Included...
See Link: https://www.rockauto.com/en/moreinfo.php?pk=49789&jsn=915
Unit shows good condition. Springs appear good.
Wear on the drive gear is mild. Shows light wear for it's age, rotates OK... use a good cleaning.
The Standard Motor Products ignition module is included. Vacuum module included. Un-modified/Un-tested.
There are at least two styles of FIVE pin modules; the fifth pin on each is used to retard timing.***
One uses (+) to the 5th pin to retard -8 to -10 degrees (Varies at RPM and by ESC Controller)
One uses (-)
It MAY fit 81-86 C10 and many other models...
No way to test this module without the retard system. Being sold AS IS FOR PARTS...
Vehicle application varies... No refunds, No returns all sales FINAL.
These pictures are the exact unit shipped.
Domestic shipping only. Unit will come well packed for safe delivery. USPS Priority mail.
If you request insurance, please add the amount based upon the delivery after we speak via email.
(A ***slightly used LARGE Cap/Rotor and UNTESTED CAP COIL can be added for an additional $25.00...)
This unit may also work for applications using the shallow or SHORT CAP / Distributor cap... Not included.
Email for pics of anything not shown... Not a business, just trying to help out with good used parts for repair.
Stuff collected over the years...
HEI No Cap No Coil: $50.00 plus actual Shipping.
HEI w/Cap and Coil $75.00 Plus actual Shipping.
Payment accepted is US Postal money order.
Please contact me for delivery instructions.
Tank6x2
Edmonton Alberta Canada
Kurt
C30
350, TH400.4:10 gears 2WD
I see the extra parts now disregard
RanchWelder
Earth
Blazer
355ci
All sale items are no longer for sale.
Trade for parts offers ONLY.
my82blazer
