5 ac compressors
Brother Bill
NM
Bill
K20 Suburban
Trying to sort out repeated AC compressor failures. On the 5th one. They dont last a day.
system flushed.
whats next?
Brother Bill
NM
Bill
K20 Suburban
85 K20 Suburban 350
What Kind of ac compressor? Pancake? Sanden
Maybe a aftermarket kit kind?
Variounsoption show us your setup.
any new components beside that?
are you using oil And the proper amount of r134a
Oil has to be compatible with the refrigerant and the compressor and the o rings.
Is a vacuum being applied to dry and empty the system?
Was it flushed?
Are they locking up, making noise, or what?
Just like dad he dropped a load and dashed to never be seen again
Or in a less graphic manor, he went for cigarettes and still we wait
Damn, I even replied 15 minutes after he posted
Doppleganger
OH-MI: Just like it sounds
Sounds like a very contaminated system. I'd be flushing/replacing the condenser as well. Do those older systems have orifices? What kind of PAG oil and how much you putting in (and where)? Some goes in the compressor - some goes in the accumulator.
I wouldn't have in my possession any compressor that wasn't made in: 1.USA, or 2.Japan.
AKguy
Alaska
Randy
K30 Crew Cab Silverado
So, when a shop tells you they checked the system for contaminants and it was clean, how do they perform the function?
Generally they are running an automatic machine that will pull the refrigerant and oil out and run it through a filter. They draw it down, then open up lines and look. You can tell pretty easily when it has a contamination issue. You'll see sparkly stuff in a line or even worse black death when you crack a line. Black death means you need to replace everything... you'll never get it out of all the little spots and it will kill a new compressor fast.
AKguy
Alaska
Randy
I have a hunch that the shop did not accurately assess the situation, has not since corrected all the issues and continues to burn through compressors.
AKguy
Alaska
Randy
Could be that, too!
AKguy
Alaska
Randy
Sooooo glad there are only two days of the year where A/C would be nice here!
Tjreid
