5.9l Cummins swap into a lucky Square Body
wildcatjason
Kansas
Jason
suburban
cummins 3.9 4bt
Well that sounds right. Both ports come off the oil filter plate. Did your engine come with a long flex tube that connects the end of it with the oil pressure switch? Mine did and every time the switch would lie against something metal it would ground out and do that. Only other thought I may have is if you changed the awg of wire changing resistance but it shouldn't be that significant.
TexasOutlaw87Cummins
santee
cody
k 30
5.9 cummins
No I just plug it straight in to the hole next to the feed line for the turbo . I don't know what it's doing that maby I need to put it on a line ? I was thinking about moving it some where else or get a nother switch it a new Switch but still good be bad I guess
wildcatjason
Kansas
Jason
suburban
cummins 3.9 4bt
The second port beside the turbo feed is where it belongs. The flex line is because the vibration of a cummins will bust off the end of the sensor.
1973 Chevy
Wisconsin
1970Something
5.9 6BT Cummins
No motivation, windchills of -35
wildcatjason
Kansas
Jason
suburban
cummins 3.9 4bt
Wind chills? That truck will not be fun to start in those temps.
No motivation, windshields of -35
I'm already seeing a diesel gel problem here. A block heater will help a little but you're prolly gonna need to use some additives in your fuel in the winter huh??? Even at 25 degrees in the middle of the night, This Cat in the C6500 doesn't like to start. The Cummins in the Peterbuilt is not to bad at 25, but in the teens it's a bitch too.
wildcatjason
Kansas
Jason
suburban
cummins 3.9 4bt
I'd consider two block heaters (the stock heater and one in the lower radiator hose), a fuel line heater, and keeping that grid heater (hopefully its still there) at -12. Turning your fuel pump up and timing advance will increase power but make cold starts worse. Keep that in mind.
1973 Chevy
Wisconsin
1970Something
5.9 6BT Cummins
Does anyone know if you can run a GM SM465 4 speed tranny with a 6bt? I read somewhere that you can on a 4bt and you can run it on a 6 but youll chew up clutches like crazy.
I'd imagine it can be adapted and had been adapted. BUT, I sure think being diesel, I'd want to go with a NV4500. Diesel like LOW rpm's. OD will be good for a 6BT and mpg even moreso than a gas engine.
1973 Chevy
Wisconsin
1970Something
5.9 6BT Cummins
I was planning on running a Dodge or GM NV4500 from the start but I was just trying to see if I could save some money.
Does the NV4500 use a larger clutch? If not, I don't see why it would make a difference.
1973 Chevy
Wisconsin
1970Something
5.9 6BT Cummins
If I could find where I read that id post it, but I can't find it.
wildcatjason
Kansas
Jason
suburban
cummins 3.9 4bt
wildcatjason
Kansas
Jason
suburban
cummins 3.9 4bt
Get yourself an overdrive the first time. I got on one of those online calculators and if you have 3.08 gears with 33's you will be turning 2030 rpms at 65. That engine redlines at 2500. You'll hate it. It's sweet spot for highway cruising is 1700-1800.
Vintage_Phinds
