Hunter79764
- Sep 1, 2021
- Grand Prairie, TX
- Shawn
- Suburban V20
I'm not a fan of the "High Mileage" oil. Everyone I know that has switched has noticed increased oil consumption, and sometimes it doesn't always get back to normal after going back to the regular stuff. Maybe it's coincidence, but I've seen it at least a half dozen times among family and friends.
I'd say use whatever the manual or engine builder calls for (up to using the "hot climate" oil even if you are in a mild climate) until you are seeing real oil pressure issues, then switch to a step heavier until you can get a rebuild figured out. Thicker oil for a car with low oil pressure is a bandaid. You don't know where those loose clearances are that "need" thicker oil, and you are trying to push that thicker oil everywhere else that is still fairly tight clearance.
I've heard mixed opinions on the ATF issue. From some knowledgable folks, the basic idea is that half a quart of ATF is unlikely to dilute the lubricating properties of the rest of the oil, but the detergent pack in ATF is meant to be MUCH longer lasting than the detergents in engine oil, and act in a different way that might help clean some sludge.
I prefer SeaFoam or Marvel Mystery Oil (which might just be modified transmission fluid?) before an oil change, although SeaFoam in the intake is the better use to me. Just notify the neighbors ahead of time, you don't want the fire department showing up
