iamtherealJayy
- Nov 26, 2021
- Tennessee
- Jacob
- 1987, 1978, 1976
- V20, K10, K10
Since the 350 in my 1978 Chevrolet K10 is getting tired and I need a clutch swap anyways I’m going to swap in an LS for better fuel economy and power. Currently I’ve picked everything except the fuel tank, sending unit, and pump. The things I’ve got so far:
-ICT billet sbc to LS motor mounts
-ICT billet sbc to LS coolant sensor adapter
-ICT billet 12.9 ls flywheel bolts
-Larlansz M16x1.5 to 1/8 npt oil pressure sensor adapter
-SACHS NFW1050 flywheel
-ARP 134-2203 pressure plate bolts (12” clutch)
-GM ACDelco 12557583 pilot bearing
-Power Torque K1909-02 12” clutch kit
-generic -6AN fuel line and fitting kit
- ls quick connect 3/8 to -6AN
- ls quick connect 5/16 to -6AN
For fuel tank I plan on using the GM1C baffled 87 tbi tank and sending unit with an upgraded pump(haven’t picked which yet) my truck is going to retain the stock ls with 0 power modifications. I’ve read between a few options including the walbro 255, and a late 90’s gmt400 stock fuel pump. My current total in just parts, adapters, etc is around $400. After I order the tank and fuel pump that will add around $250. I’m going to pick up a stock early 2000’s drive by cable 5.3 with an already worked harness ready to drop in. I’m mainly making this to ask is there anything I’m forgetting? I’ve been trying for three days now to make sure I had everything before I hit order. I also wanted to share part numbers of everything I’ve ordered so far.
