5.3 swap-stock gauge info
oldironryan
Arkansas
Ryan
Suburban & K20
5.3 in Burb, 350 in K20
I've got an 85 suburban that is getting a 5.3 put in it. Any ideas or direction on getting the coolant temp gauge and/or the volt gauge to work?
tanz45
Hopewell, PA
Use factory wiring, sensor, and obtain the threaded adapter from summit. Remove large allen key bolt on passenger side head. Install adapter and then install factory 85 sensor. Temp will work.
oldironryan
Arkansas
Ryan
Suburban & K20
Thanks!
Houston Ben
Houston
Ben
Sorry to sound ignorant but do you have a part number or actual name? I can't find it...
tanz45
Hopewell, PA
Here ya go, just copied over my LSx part swap list from other thread
This is what I used with my swap and a standalone harness mated with a TH350 trans.
http://www.summitracing.com/parts/dak-sen-01-4160 speed sensor (to give ECM a VSS pulse)
http://www.summitracing.com/parts/atm-2268 oil pressure sensor adapter
http://www.summitracing.com/parts/atm-2277 temp sensor adapter
http://www.summitracing.com/parts/rus-644000 Fuel feed adapter AN to return style fuel rail
http://www.summitracing.com/parts/nal-12563532 Flex plate adapter for converter
http://www.summitracing.com/parts/arp-244-2901 Longer flexplate bolts
http://www.summitracing.com/parts/vpn-gsl392 Walbro 255lph fuel pump
http://www.jegs.com/i/Schoenfeld/649/1302LS1/10002/-1 Headers, they do work with the square bodies, may need to alter trans member
Motor Mount Adapters: You are going to want 1" back setting
Houston Ben
Houston
Ben
Here are the part numbers that I bought from Summit. I don't have them yet but have found some people that used them and it works!
ATM-2259
ATM-2277
goes into the pass head where the allen bolt is located.
thatgermanguy
