Irezel
- Sep 22, 2017
- Indiana
- Brandon
- Suburban k20
Im wanting to make 496 built more for low end torque and run on pump gas. It would be used in a 81-91 Suburban 4x4(One of my fav vehicles). I have never built an engine before, but I have been around cars all my life as my dad is a mechanic. I think I listed everything I would need and think it is also all compatible. But I would like if some experienced people could read over it and just make sure im not missing anything and that it won't blow up . It might take a while to save up for it though as its almost 10k as it is now. Also wondering what a good trans to put behind it would be. Haven't desided if I want Auto or Manual yet but would like to hear options. And if you can, i'd like to hear some HP/Torque estimations and at what RPM. Thanks
Looking to make mid 9 to 1 compression ratio and if I did the math right, it would be 9.53 to 1. I would like if someone else that knows what they're doing to double check. Bore: 4.31 Inch, Stroke: 4.25 Inch, Head Volume: 118cc, Piston Volume: -18cc, Gasket Thickness: 0.08 Inch, Rod Length: 6.385, Deck Height: 9.8 Inch Milled down 0.02(9.78 Inch) Inch to make the deck clearance 0(I believe).
*Updated*
-Engine Block - Part Number: Chevrolet Performance 19170538
Deck Height: 9.8(Milled down 0.02 to achieve 0 deck clearance)
Bore: 4.250(Bored to 4.310)
1-piece Rear Main Seal
4 Bolt Main(Not spayed)
Cam bearing included
Freeze plugs included
-Crankshaft - Part Number: SCAT Engine Components 4-454-4250-6385-L
Rear Main Seal Style: 1-piece
Stroke: 4.250 Inch
Material: Forged 4340 steel
-Main Bearings - Part Number: Clevite Engine Parts MS829H
Grooved Bearing: Yes
Groove Location: Upper
Groove Style: 1/2
Material: Tri-metal, TM-77
-Pistons - Part Number: Sportsman Racing Products 142980-8
Bore: 4.310
Type: Flat top, with single valve relief
Material: Forged Aluminum
Compression Distance: 1.270
Piston Volume: +3.00cc
-Piston Rings - Part Number: JE Pistons S100S8-43105
-Connecting Rods - Part Number: SCAT Engine Components 2-454-6385-2200
Length: 6.385 Inch
Style: H-beam
Wrist Pin Style: Floating
-Rod Bearings - Part Number: Clevite Engine Parts CB-743HNK
-Camshaft - Part Number: COMP Cams 11-413-8
Type: Hydraulic roller tappet
Duration at 050: 212in/218ex
Advertised Duration: 264in/270ex
Valve Lift: 0.510in/0.510ex
Lobe Separation: 110
-Timing Chain And Gear Set - Part Number: COMP Cams 2110
Type: Double roller
Max adv at Cam: 2 degree
Max adv at Crank: 4 degree
-Oil Pump - Part Number: Melling M77
Type: Wet sump
-Oil Pump Pickup - Part Number: Summit Racing SUM-G3622
Oil Pan Depth: 8 Inch
-Oil Pump Driveshaft - Part Number: IS-77
-Oil Pan - Part Number: Summit Racing SUM-G3606
Rear Main Seal: 1-piece
Max Stroke: 4.250
Rear sump: wet
Depth: 8 Inch
-Gasket Set - Part Number: Fel-Pro CS8523
Included gaskets: Oil Pan Gasket, Rear Main Seal, Water Pump Gasket, Timing Cover Seal,
Water Neck Gasket, Fuel Pump Gasket, Distributor Gasket.
-Head Gaskets - Part Number: SCE Gaskets P14324
Bore: 4.320
Material: Copper
Thickness: 0.043 Inch
-Pushrods - Part Number: Lunati 8200-16
Ball Tip(Top and Bottom)
Diameter: 3/8
Length: 8.275 In, 9.250 Ex
-Rocker Arms - Part Number: COMP Cams 1411-16
Ratio: 1.72
Type: Roller tip
-Lifters - Part Number: Lunati 72331-16
Type: Hydraulic Roller
Includes Link Bars
Outside Diameter: 0.842
-Cylinder Heads - Part Number: Stock cast #336781
Material: Cast Iron
Chamber Volume: 113cc
-Head Bolt Kit - Part Number: ARP 135-3601
-Spark Plugs - Part Number: Autolite 3924
-Water Pump - Part Number: Summit Racing SUM-312461
Flow: High-Volume
Material: Iron
Rotation: Clockwise
Pilot Diameter: 0.625
-Intake Manifold - Part Number: EdelBrock 7561
Type: Dual Plane
Material: Aluminum
Single Carb
-Water Neck - Part Number: Spectre Performance 42313
-Distributor - Part Number: Summit Racing SUM-850050
Trigger Style: Magnetic
Advance Type: Mechanical
Cap Style: Male/HEI
-Spark Plug Wires - Part Number: MSD Ignition 31803
-Carburetor - Part Number: EdelBrock 1812
CFM: 800
Choke: Manual
Barrels: 4
-Carburetor Mount Stud Kit - Part Number: Spectre Performance 42513
-Engine Bolt Kit - Part Number: Professional Products 53130
Includes: Intake Manifold Fasteners, Valve Cover Fasteners, Timing Cover Fasteners,
Oil Pan Fasteners, Header Fasteners, Water Pump Fasteners, Fuel Pump Fasteners,
Water Neck Fasteners, Distributor Clamp Bolt Fastener
-Oil Filter - Part Number: ACDelco 25324052
-Valve Covers - Part Number: EdelBrock 4683
Height: Tall
Material: Steel
-Valve Cover Gaskets - Part Number: Mr. Gasket 586G
Material: Cork/ Rubber with steel core
Thickness: 0.188
-Timing Cover - Part Number: Milodon 14875
Type: 1-piece
Material: Aluminum
Fits stock and double roller timing chains
-Timing Cover Gaskets - Part Number: Fel-Pro TCS45053
Material: Fiber
-Air Cleaner - Part Number: Edepbrock 1223
Type: Round
Size: 14 Inch Diameter, 3 Inch Height
Top/Base Material: Steel
Filter Material: White Paper
-Valve Cover Breathers - Part Number: Spectre Performance 4277
*Updated*
Stroke: 4.250 Inch
Groove Style: 1/2
Bore: 4.310
Length: 6.385 Inch
Style: H-beam
Type: Double roller
Type: Wet sump
Max Stroke: 4.250
Rear sump: wet
Depth: 8 Inch
Bore: 4.320
Material: Copper
Diameter: 3/8
Ratio: 1.72
Type: Roller tip
Includes Link Bars
Material: Cast Iron
Flow: High-Volume
Material: Iron
Rotation: Clockwise
Type: Dual Plane
Material: Aluminum
Single Carb
Cap Style: Male/HEI
CFM: 800
Choke: Manual
Barrels: 4
Height: Tall
Material: Steel
Thickness: 0.188
Type: 1-piece
Material: Aluminum
Material: Fiber
Type: Round
