454 with 10 bolt rear end?
hirschdalechevy
norcal
rich
k-30
Back in the day , I sunk a bunch of money into my 12 bolt , super brute limited , Richmond gear's , alloy axle's , etc. With a 425 horse small block , auto tran's and 35x14.50 ground hawg's I used to spray that 12 bolts gut's out on a regular basis , (three times to be exact), I was hard on it though. Strong torque and big rubber don't mix very well for a 12 bolt. You might be ok with a stock big block and 35's as long as you don't beat on it but I wouldn't put any money into a 12 bolt with a big block and 35's myself , ( I learned the hard way , three times). 14 bolt is the way to go and they are cheap and easy to swap. As for the front the dana 60 is the way to go but they are not cheap and not as easy to find. I have had good luck with the 8 lug 44's and big rubber as long as you leave them open carrier. I was going though axle joints on this same truck for a while so I up graded to chromoly shafts and cmt joints, made my own axle truss, and then it was all good. By this time a dana 60 would have been nice but I didn't have one so I went the 44 route. The 44 will work well as long as you don't hammer it to hard off road. The only thing I ever broke on a 44 was axle joints which in turn took out the axle's as well, (and one time a housing , jumping), not the 44's fault just my stupidity.
hirschdalechevy
norcal
rich
k-30
eskimomann209
Modesto
Marcus
I don’t see a 10 bolt holding up my dear sir
I tried it with a 305 and 35 inch tires I got a few years out of it
It’s your fireside AND engine that’ll be the death of it. Even babying it.
The 12 bolt SF will hold up better especially because the sm465 isn’t a power monger but it can torque the 12bSF to death.
I do like the 14BFF but it’s 8 lug and you’d need fronts to match o course.
I have a 12b with post in mine and next in is a ls 383
So I’ll have more answers in the 383 question here in the future:banana-mario:
1973c10
Don
I hear ya Don but I just have to say (to everyone else)
..WARNING.. This doesn't mean a 12 bolt behind a bbc can handle getting hammered on forever, by whoever..! ... END OF WARNING..
Nothing last forever LOL
rpcraft
Robert
Jimmy
LS 6.0 364 CID
I did not realize we were talking about a big block and big tires. that 10 bolt will be living on borrowed time if that is the case, lol. Drive sparingly to make it last. I'd look at a Semi float 14 bolt or a full floater, and as long as you do not flog it your front 10 bolt can be ok. I'd just be sure not to try and get the front wheels wedged or locked up though. If you gear it well it can be upgraded with the 31 spline hardware but then your front diff can be the weak link. Just food for thought.
shiftpro
BC Canada
shiftpro
350, 383, 454, 496!
That 10 bolt he built needs a 2x stepside with a 327..
Derick C.
Auburn WA
Derick
454/700r4
I have a 10 bolt in my suburban that has been worked very hard and hasn't broke yet but I know it will eventually, that's why I have been building a 14 bolt FF that will be going in within the next few months.
Derick C.
Auburn WA
Derick
454/700r4
82c10stepside
Montoursville, Pennsylvania
Tim
The leverage of a 35 inch tire will be the death of it if you drive it like you stole it. Drive it like it's your own money and it will probably live a long time.
rpcraft
Robert
Jimmy
LS 6.0 364 CID
If he has the right gearing it will be ok for daily driving, towing, and mild wheeling. If he puts the truck in a situation where the tires are wedged in and using some serious torque or like the gas pedal is a light switch then yes, there is going to be some carnage, lol.
ben_swager
