454 Oil Pan
Powerhouse Ranch
3G Connoisseur
PA
Luke
1980 & 1988
C25 & V15
454 & 350
There was a very embarrassing moment and i now need a new oil pan for my 454 Big Block for my 1980 GMC C2500. Best place to get them? Also, LMC doesn't have my year, unless of course it falls under another category. ANY HELP IS APPRECIATED
Paladin
"Teufelshunde"
Wichita Falls, Texas
C30 Silverado Crew Cab Dually
AWWWW, come on man, we need details first! How did you **** it up?? LOL:smokin:And if the story is really good we need pics to go with it!!!!:popcorn:
Powerhouse Ranch
3G Connoisseur
PA
Luke
1980 & 1988
C25 & V15
454 & 350
as long as no judgemet occurs. frankly i'm taking it pretty hard, being the original oil pan and all that :(
so last spring when i changed the oil for the first time since ownership, i was taking the plug off with one of my dad's 1/4" ratchets. Little did i know, that his ratchets "ON AND OFF" were backwards compared to what i had at work, so yeah it was tight and i'm thinking, "ah it's been a while" and then i stripped the pan tightening it to death instead of loosening. When i had realized it was too late. End of story. Somehow i managed to get the plug in enough afterwards (don't ask) and i dreaded the next oil change, which was today, and it just ain't gonna cut it. Highly, HIGHLY pissed off about it. One dumb little moment is all it takes. SO anyway, i was hoping to drive it next week when the weather was nice, thus the fresh oil change for the spring/summer but it went downhill. Need a good oil pan ASAP
Paladin
"Teufelshunde"
Weld a bung in the old pan and use a pipe plug. Would make it usable until you find an appropriate replacement if you still wanted one!:party52:
Powerhouse Ranch
3G Connoisseur
PA
Luke
1980 & 1988
C25 & V15
454 & 350
i'm pretty set on getting a new pan overall, plus i really wouldn't mind looking at the motor's undercarriage with the pan off. the main thing i'm wondering is is the 73-74 454 option in LMC above going to be the same for my 80? Is that why the 80 isn't an option?
AKguy
Alaska
Randy
K30 Crew Cab Silverado
This one should work for you.
1985c20
Torrington, CT
Chuck
They sell oversized drain plugs for fixing stripped plug threads. They cut the thread a little bigger the first time you run it in and you’re good to go. Or they have ones that a bigger plug threads in then there’s a smaller one that comes out the center. Called piggy-back plugs sometimes. There’s also repair kits for around $20 on Amazon I’ve never used them before though.
Turbo4whl
Downingtown, PA
Wayne
My question, can you even remove the pan without lifting the engine out of the cradle? Four wheel drive no problem, but this 454 is in the C2500?
I also would recommend a repair.
Powerhouse Ranch
3G Connoisseur
PA
Luke
1980 & 1988
C25 & V15
454 & 350
interesting
Powerhouse Ranch
3G Connoisseur
PA
Luke
1980 & 1988
C25 & V15
454 & 350
i may have to, not sure yet. looks like there may be clearance
yevgenievich
Place
Name
Year
Model
Size
I had done c1500 oil pan by moving motor mount stands while holding the engine up with blocks of wood. Was not fun. But better than on el camino, had to tilt everything with trans unbolted to get clearance
Craig 85
Nashville, TN
454/TH-400/NP205
Someone installed a car engine in my truck at some point. When I got the new GM crate motor that pan would not fit the pick up. I got this truck pan from Assault Racing. $52.02
Assault Racing Products ARC A9294-2
This is a new black painted big block Chevy oil pan. Pickup style with clearances for 2 or 4 wheel drive trucks. Fits Mark IV 1966-1990 396, 402, 427, and 454 engines with 2 piece rear main seal.
  • Black painted stamped steel pan
  • Rear sump
  • 6 qt. pan capacity
  • Baffled
  • Dipstick on passenger side
  • 8 3/4" deep
Knight84
Alabama
Alan
That's the one I just ordered. Should be here Saturday, and going on this weekend. Hopefully it won't be a bitch like my xj was.
rljohnson013
