454 engine
Knuck55
Chesapeake Va
Dave
1988 and another 1988
Suburban V10 G20
Greetings all,
Anyone here have any knowledge about what MPG I could expect from an 88 Suburban with a 454? It only has 34,000 original miles but the guy that owns it did not change the oil enough and pulled a large camper trailer and it has a knock which I determined to be a rod for sure. I have a chance to buy it for 5 K. It is a 3/4 ton with ZERO rust. Any help would be appreciated.
Radiohead
That guy on the Columbia
MCMLXXIX
C-20 Silverado Camper Special
Maybe in the 12mpg range if you stay out of it, assuming everything else is good. That might be a bit generous too. It's not going to go easy on the wallet regardless. :cool:
85K304SPD
Las Cruces, NM
Richard
Is it 2 or 4 wheel drive? Just curious. The best I can get out of my 383 is 10 MPG.
shanegtr
Perth, Australia
Shane
R2500 Suburban
11MPG from my 454 TBI
Anywhere from 10 to 13mpg. Depending on the tune, gearing, and ride height.
Knuck55
Chesapeake Va
Dave
Suburban V10 G20
Thanks to all. I can live with that. I did end up with the burb and will be making sure of the knocking noise before I go pulling the motor. I have had loose converter bolts fool me more than once! Best score of my life though on this body!
Knuck55
Chesapeake Va
Dave
Suburban V10 G20
2 WD but I have a complete 4WD drive train in my back yard... It may just find its way under this 3/4 ton. Will leave the 14 bolt in the rear.
78C10BigTen
pennsylvannia
C10 BIG TEN
Well then i think pics are in order! Lol
Knuck55
Chesapeake Va
Dave
Suburban V10 G20
They be coming soon! Both my burbs now. It was the converter bolt by the way. Dont have to pull the big ass motor out!
IdahoJOAT
Idaho
Rodger
What gearing is it? On what size tires?
Odis
