4:10 gears for 86 k10
Rjckey
florida
Rickey
Don’t know much about gearing but I will be putting at least 35in tires on a 4inch lift k10, looking for recommendations on what companies make good 4:10 gears.
Edelbrock
Earth
Grumba
K5 Blazer
You installing a locking diff? If it were me, I would just get a complete junk yard axle that has a factory LSD. Is your rig a 4x4?
Frankenchevy
Proverbs 16:18
USA
Square
CUCV
Small
OP said k10, so 4x4.
If you aren’t doing the work yourself, I’d find the shop that’s doing it first. They’ll have a supplier they like to use that should have a few options. That way there are less questions if they need to warranty the work.
Otherwise, there are several options that’ll work manufacturer-wise.
Rjckey
florida
Rickey
I’ll be doing the work myself
Rjckey
florida
Rickey
Rigid axle seems to make a pretty decent priced one just don’t know how reliable that brand is
nvrenuf
Mobile, Al.
@Rjckey do you have an overdrive transmission? If yes, I'd go with 4.56's (I used this combo in my old crew cab, it drove great). If you do not have overdrive, 4.10's are a little less than idea but not horrible and livable at highway speeds.
Camar068
10 yrs Air Force
When i still had 31" tires, I wish I had put 4.10 gears on it. Now I'm on 32's....really wishing I did. 4l60E in mine. You go up to 35's, you may feel the same. Put your info in the calculator below to help make a decision. Also below is a sample chart to help you decide.
RPM calculator
Gearing chart
Rjckey
florida
Rickey
I do not have an overdrive transmission, I have a th400
Edelbrock
Earth
Grumba
K5 Blazer
RPM calculator
Gearing chart
Nice links.
jborders
