350 turns over slow after getting hot
OrangeC20
Walla walla
Reuben
My truck will start up no problem first thing in the morning, I have a 30 minute drive to work and when I try to start it 10 minutes after I get to work it cranks really slow. After it cools down it starts right back up. Any help appreciated
Georgeb
Wisconsin
George
K10 Burb Z71
your starter is taking a crap. time for a new one before you get stranded.
yevgenievich
Place
Name
Year
Model
Size
Sounds like weak starter/heat soak on the starter. Or too much timing advance. Does the starter have a factory heat shield around it?
Christian Nelson
Wisconsin
Christian
K15
Starter is going bad.
Get a brushless mini starter. They are on Amazon for around $50, Might even find it for $30-ish..
They resist heat soak way better, and no brushes to wear out.
87ChevyR10
Kansas
NA
NA
NA
IF you are running long tube headers, your starter NEEDS a heat shield. I had an '85 Silverado with a 355 and I was replacing starters almost weekly. There was an immediate difference after installing the heat shield. Truck had same symptoms: good cranking when cold; hot cranks were slow or non-existent.
OrangeC20
Walla walla
Reuben
Nope, no head sheild. I have one somewhere I picked up from a guy but I'll have to find it. And yes long tube headers
yevgenievich
Place
Name
Year
Model
Size
Starter might need to be replaced anyway due to running without a heat shield, but worth trying with a heat shield and see if it still works well enough
fussfeld
east coast
j
c-10
4.3 v-6 262CID
i'm with yev; You need a heat shield irregardless. So try one and it may cure the problem completely and you won't need a starter so soon.
i'm using the Taylor wrap, part #2540 with very good results---i had the same symptoms and the wrap corrected all that.
87ChevyR10
Kansas
NA
NA
NA
I can say this, even with a heat shield, the starter will get heat soaked. I ran my truck up to 100 mph the other day for about 5 minutes or so. My starter is not the happy sounding starter it used to be. It still cranks over, but has a different sound to it.
chevyk10
WV
Daniel
1984 chevy
k-10
358 Dart block with aluminum heads 430hp/450ft-lb torque
Pay a little more and get a mini starter. No problems after that. IMO
Sent from my iPad using Tapatalk
smoothandlow84
I'd rather be draggin' frame
Steve
1500 r10 pavement scraper
Whats better, the aluminum heat shield or the insulating wrap / blanket?
fussfeld
east coast
j
c-10
4.3 v-6 262CID
Not sure, but i choose the blanket because i thought it would be easier to install. Works well for me.
Eh, I've never run heat shields before with headers. A weak battery can also make a good starter seem like it's failing. And it seems like nobody makes a good battery anymore. So even if the battery is newish, it can still be the problem.
zapattack
