350 TBI Engine Oil Cooler Diverter Seals R & R
I just talked to my parts man, he will have the kit for me after lunch. In the mean time I will take the rest apart and clean it and fix that alternator wire. I'll post the alternator pics in that other thread. A big thanks again to Skysurfer for the info.
I got to dig out the torpedo heater and set that sumbitch up next to the truck. ;)
Looks like you're getting 'er taken care of man. very good pics!! Thanks for the info, man!
I figured I'd post as I go along to list the tools and sizes needed, hopefully that will help anybody else in that situation to be prepared. :)
Skysurfer, I see some kind of white sealant on top where that o-ring sits, did you use sealer to put it back together?
Fired up the heater, temp is dropping today.
One good rap of the mallet popped the diverter roght off the oil limes.
******, old, stiff, broken orings and gaskets fell off after I removed diverter(Thanks Skysurfer for the correct terminology).
Some kind of white sealant on the upper o-ring flange, should I use sealant for this on the install???
Cleaned mating surface of block and oil line nipples.
2 more shots of diverter. Is that a relief vale in the middle where that spring is? Note broken gasket piece at bolt hole.
Numbers on side of diverter.
Cleaned up the diverter the best I could, and looked for any hidden particulates in the ports. Parts man just called and said the parts arrived. Gonna run down and get them and grab some lunch, be back in a bit.
Might as well change the oil while I'm under here. 9/16" wrench.
Trivia, what trans is this?
Underneath of truck is covered with oil all the way to the rear bumper. That's the redneck way of a chasis lube. :)
Name that transfer case....
The trans looks to be a TH400. Is that right?
I have no idea, that's why I am asking, haha.
I just got back with the new seals, I will install and report.
haha!! I thought you were starting a game of "stump the chumps" or something :D I'm pretty sure it's a TH400 but I'm sure HRPC or Retro will chime in with the for sure answers on both that and the T-Case :)
I guess I am just going to put the oring in with some grease, I don't see why I should put sealer on it. I asked a mechanic next to the parts shop and he said I shouldn;t need it. I hope not.....
RetroC10Sport
Green Bastard Parts Unknown
Jay
pontiac aztek
You have a 700r4 as it's a 4 speed and the pan is square. Turbo 400s are 3 speed and the pan is oblong.
hmmm...in the pic the tranny did look oblong to me but you got me on the 3 speed part. I forgot his was a 4 speed or I would have never guessed the TH400 :D hahaha...
Thanks Retro.
Ok, here's the kit that Skysurfer mentioned. Came with an extra 2 o-rings and a gasket I guess that are for other vehicles.
I used Syl-Glyde grease to hold the o-ring in place...
The gasket for the top I slapped a dab of grease on and stuck it up in the block, because it kept falling off trying to manuver the oil tubes into the fittings on the diverter. You can also see the new oil tube o-rings installed. Just coated those nipples with oil that was dripping out of the tube into my eyes to help the new o-rings slide right on.
Here is the diverter test fitted.
Here is everything bolted and screwed togehter.
New filter and oil. Filled the new filter with a quart of oil and lubed the sealing ring.
Installed, test run, no leaks!!
Now clean up time....:flipthebird:
This has definitely been educational for me, man! I've never had one of these go out on me. Nice job on the write up and details :)
Swims350
Logan WV
none
looks like a newer np241 t-case same as my 88 k1500 truck but on them it's ds drop and the squarebodies had some ps drops which are a nice way to do an all chevy solid axle swap on the IFS trucks. That way you can use the ps pumpkin front diffs and the ps drop t-case. if it aint a 241 it's a 208, but I'd bet on a 241.
nxtlevl
Hutchinson,KS
Ed
Glad you were able to locate and fix the problem..:)....Your posts are always detailed and are extremely helpful with the pics you take..:favorites13:
willfill
