305 No power.
Quadrajet Power
Waring, Tx
Mark
K5 Blazer
Could have got some junk inside the carb though, restricting fuel flow.
Did you pull the new pump and look at the arm? Make sure you get it under the actuator.
Skweegle89
Oklahoma
Are you running an inline filter or an internal filter? Or both?
Tricky991
Aaron
I did pull the pump and it looked fine to me. The old one that I pulled off because it was leaking a little from the weep hole. The arm barely moved at all not even 1/4 inch movement. But it worked fine never did this. So hopefully something is just got junk in it and clogged.
Tricky991
Aaron
Just running the filter that is in the carb where the fuel line screws in. Replaced it the sametime I rebuilt the carb
firebane
Calgary, AB
Curtis
If it has a check valve make sure you put the filter in the correct way other fuel will not flow.
Skweegle89
Oklahoma
It could be that you just got a bad pump. Seems like that's been happening a lot lately. Not just with fuel pumps. We just put 3 thermostats in my sisters car. 1st two were faulty right out of the box.
Tricky991
Aaron
Yeah I know seems like every part I have been getting lately have to return it at least once. Thought it was just my bad luck lol.
350runner
tx
Ceasar
It can look ok but be a dud.... they don't make em like they used to.
I don't know about the rest of you guys, but I find changing out the fuel pump on these trucks to be a major pain in the ass.
Why not just test it for flow and pressure before you spend the time changing the pump.
To check volume/flow, pull the fuel inlet to the carburetor and stick a rubber hose on it. The other end goes in a container - a beer can works.
Crank the engine for 15 seconds - with the hot wire to the coil pulled. After 15 seconds, check the volume of gas in the beer can. Anything over 8 ounces is well within spec.
To check pressure - without the hassle of teeing in a gauge. Just attach a gauge to the end of the same hose used in the volume test (0 - 15 psi gauge is plenty).
Reattach the coil wire and fire it up. It doesn't take hardly a second to get a reading on the gauge, so whatever gas is in the bowl should be plenty to check the pressure. If you need to, you can keep it running for longer with a can of ether. If you get at least 5 psi discharge pressure you are good (factory spec is 4 to 6.5)
If the pump fails either test - and this apparent fuel flow issue has only developed since the new pump was installed, check your pump suction hose for pinch points and also check the steel discharge tubing for a kink. If your piping is okay, bring the pump back to the parts store.
If the pump passes both the volume and pressure tests, look to the carburetor as the problem (specifically, the bowl float not opening wide enough).
Tricky991
Aaron
I pulled the passenger side valve cover off. And found the back 4 valves loose, some enough to pick up and turn around. So I am going to snug up that whole side and hope for the best.
Also since I have it torn all the way down to the timing chain I am just going to replace the timing chain and gears, fuel pump and the water pump cause its squealing.
350runner
tx
Ceasar
Just do a valve adjustment bud. They can't just be snug. It's really simple :)
firebane
Calgary, AB
Curtis
Make sure you pull those push rods as well and make sure they are flat. Loose rockers can bend or break push rods very easily. You may also want to look at your lifters too and check the bottoms.
Tricky991
Aaron
Ok how do I go about that?
Ok I will pull them and check that all. After I get the timing chain and everything else back on.
Thanks for all the tips and help guys!
firebane
Calgary, AB
Curtis
Follow this chart...
To ensure your at #1 TDC #3 intake will be open
To ensure your at #6 TDC #2 intake will be open
How to ensure proper lash? Lift up and down on push rods until all play is gone then tighten 1/2 turn
350runner
tx
Ceasar
This only works method only works if you don't have a cam with allot of duration. If you have a stock cam or close to this method is the easiest if them all. Props to firebane.
DawgmanDew
