205 vss conversion?
kleedus
wyo
Ray
1960 threw 91
c10 to k30
350 threw 454
ok little update the s-10 reluctor ring does not fit the 205 shaft
Was it a 231 and did it have a 27 spline output? I don't remember what the S10's got.
kleedus
wyo
Ray
1960 threw 91
c10 to k30
350 threw 454
i do not know what tcase the s10 one is i just had it in a junk pile and thought i would see if it would work.
i need one from a 241 a buddy has some trucks with them i can pull the ring from one of them just have to go out in the cold to do it
RetroC10Sport
Green Bastard Parts Unknown
Jay
pontiac aztek
My S10 has a 241c.
[edit] I take that back, it's supposed to have a 231c but I could swear I saw 241c on the tag, will have to look nect time.
kleedus
wyo
Ray
1960 threw 91
c10 to k30
350 threw 454
got the right reluctor ring from a 241 froze my ass of under a truck today
and dropped the parts off to get the hole for the sensor and to get the ring trimmed to the same width as the speedo drive gear
Swims350
Logan WV
none
I gotta keep a close watch on this, I may have to track down a 205 and do this to make vss work.
I've been having trouble finding a 2 pulse or 2000 ppm generator or speedo sending unit to work with.
I checked jegs and summit and most are 16 or 8, not 2
I did find one on jagsthatrun though.
still a good topic, I wonder if you can do the same to a 208?
kleedus
wyo
Ray
1960 threw 91
c10 to k30
350 threw 454
some 208's came with a vss i had a 4 speed 208 out of a 89ish blazer that was vss i sold the combo for 500 bucks
kleedus
wyo
Ray
1960 threw 91
c10 to k30
350 threw 454
the machine shop got it done it worked out great
241 reluctor ring and sensor
Lookin good. :cheers:
kleedus
wyo
Ray
1960 threw 91
c10 to k30
350 threw 454
so to recap
i used a reluctor ring and sensor from a 241
the reluctor ring needed to be trimmed to the same width as the speedo drive gear.
and i had a local machine shop machine the flat spot and drill and tap the hole.
the flat spot sets the gap between the sensor and the reluctor ring. the gap should be .010 to .012.
the speedo cable hloe needs to be pluged
i got the reluctor ring and sensor for free so all that this cost me was 75 bucks for the machine work.
kleedus
wyo
Ray
1960 threw 91
c10 to k30
350 threw 454
I did this back in 2013 when very few people had thought it up. Now there are at least three companies like off road design north west fabworks and other offering to do the machine work to do this. Lol
TDW1
