2008 corvette
78C10BigTen
pennsylvannia
Ted
C10 BIG TEN
Got new bearing for the transmission and it is back together after baking some gears. Back to good preload, no noises and all working gears. Too bad I don't get to actually use it. Anybody want to buy a complete ls3?
Enlighten me... why bake gears?
RecklessWOT
New Hampshire
Kevin
V10 Suburban Silverado
That is done a lot in the aerospace manufacturing world too. Trying to insert steel bearings (or bushings etc) in an aluminum housing they heat up the aluminum in an oven (or with torches depending on size) and drop the bearing race in liquid nitrogen. The steel shrinks with cold temps and the aluminum expands when you heat it up, then you can simply drop it in and when it all gets back to normal temp it's never coming out. That way it's press-fit without having to worry about the steel shaving/gouging the aluminum while being forced in there. If you can make it drop into place you get the same fit with no risks of damaging during assembly
yevgenievich
Place
Name
Year
Model
Size
Following the usual routine. Rad support piece broken on this one as well. But this time I have a whole front frame section to test fit on before trying to install.
yevgenievich
Place
Name
Year
Model
Size
Having a frame section for mock up helps a lot. The piece was not only broken, but heavily bent/twisted
82sbshortbed
Fuckemall!!
SE Texas
Doug
1500 shortbed, 1500 longbed
What do these dumbasses keep running over? Lol, that's about 3 now that have had that damage?
gotyourgoat
NRV Virginia
gotyourgoat
smokin' 305
Yeah really. Is this a common weak point on these or does @yevgenievich just have the luck of having this issue.
Do they make skid plates for c5's?
yevgenievich
Place
Name
Year
Model
Size
Make it 4 out of 4, a friend of mine also picked up a c6 and it is broken. Hitting a dip at normal speed almost guarantee contact. C5 used a steel version I believe instead of aluminum
yevgenievich
Place
Name
Year
Model
Size
08 is officially gone.
holy cow :rofl:
yevgenievich
Place
Name
Year
Model
Size
And a bit of shade tree air dam repair.
yevgenievich
Place
Name
Year
Model
Size
Downside of light color carpet are the spill stains. Got it better and left it on that. Sanded the yellow clear coat off the headlights. Lenses still trashed, but looks a bit better. Also needed to pass inspection, so some stock rear wheels made it on there for a day.
ben_swager
