2000s hydroboost into a square
RoryH19
Rory
R10 Silverado SWB
Has anyone installed a hydroboost from a 2003, 4, 5... suburban, Tahoe, escalade... into a square?
If so, assuming I would have to use the pedal, hydroboost unit and master cylinder.
Power steeping pump would also need the extra connector.
Thanks.
climb-101
montana
seth
c2 crew cab
6.0 LS
i put the one from the 2006 truck in mine. i used the stock brake pedal and just matched the connection point from where it pivots down to the rod. I also had to cut the rod coming out of the master and thread it so i could attach the original push rod.
as far as the engine side, i mad a new bracket for the master so i could use the original studs on the firewall and i had to enlarge the original hole a little where the rod goes through the firewall
RoryH19
Rory
R10 Silverado SWB
Thanks.
I thought it was possible but knew it would take some work.
TPISly-C10
Boucherville QC Canada
Sly
C-10 shortbox
LQ4 6.0L
i'm OEM HB and this is the best brake set up you can have! maybe gonna upgrade it whit the bigger recent one some day! :)
RoryH19
Rory
R10 Silverado SWB
Thanks.
I think that's what I'm going to use. That way I know everything will bolt up with no issues.
Now just need to find one.
MatrixFab
NorCal
Daniel
C/K 20
Anyone have a build breakdown or part number data sheet? Interested in the swap.
SirRobyn0
Thanks.
So here is my question, why would you want to do this swap? I've been a mechanic for pushing 30 years, so I know the standard GM vac system and the hydroboost system and have worked on both. I've also owned both. For me I do not see the appeal to hydroboost except where there isn't enough room for a vacuum booster, or perhaps if your converting to a diesel. for me I don't like the brake pedal feel. I'm not trying to discourage you at all, I'm just curious.
eskimomann209
Modesto
Marcus
Or a large cam. Hydroboost is good for those too.
roundhouse
atlanta ga
justin
77,78,79,80 ?
The 6.2 diesel squares had a hydro boost from the factory
Should be a bolt in deal
Craig 85
Nashville, TN
454/TH-400/NP205
Here's info for a 79-84 HB system. I know the mid 85 to end of model year 86 is a little different due to the accessory drives being modified for dual smog pumps.
MatrixFab
NorCal
Daniel
C/K 20
Thanks Craig 85! Very helpful data.
Keith Seymore
Motor City
Keith Seymore
4.3L
I'm kind wondering, too, why would use a newer hydro boost setup when you could use one off a square body.
Unless you already happened to have a newer one.
K
RoryH19
Rory
R10 Silverado SWB
K
It's more about availability. I run across the 2000's all the time. Hardly see any squares that have them.
I would prefer to use a square one.
Keith Seymore
Motor City
Keith Seymore
4.3L
Understood. Makes sense.
K
bglendon
