82sbshortbed
Fuckemall!!
- Mar 1, 2018
- SE Texas
- Doug
- 1500 shortbed, 1500 longbed
Ok now I think my battery is finally taking a ****. It's a red top but, I bet it's pretty old. Po had it in there. I've had it for 5 years and only pit a couple thousand miles on him. Did hook up trickle charger but, I think it's done.
Thought the alternative bad but, tested it and it's over 14v at idle but, when you Rev it and let off the voltage goes down to 12 then dies.
Tried to die at stoplight on the way home. The ac fan slows as I get up in rmps under load. Reving it while in driveway ac fan doesn't slow. I cleaned the ground and greased it. So battery looks like it. What yall think?
Been kinda sluggish until 2500 or 3000 rmp too. That's when ac fan slows to nothing. Then let up and back to full speed.
