2000 6.0/4L80E in '84 SWB Chevy
Gray97
Kansas
Grayston
327, TH350
Did you run it after you got it?
No I didn't but he did drive and parked it where I could swap it. I never did disconnect anything yet so maybe I could if I had a skid steer.
350runner
tx
Ceasar
Prob just the pcv or blow by. A look in the intake will tell.
Gray97
Kansas
Grayston
327, TH350
True, I took of a valve cover that has the hose going to it but it almost looked bone dry
350runner
tx
Ceasar
Is the pcv built into the valve cover?
350runner
tx
Ceasar
Yea Look into buying a new one
Gray97
Kansas
Grayston
327, TH350
Ok, anything in particular valve cover wise or just stay with a stock ones?
350runner
tx
Ceasar
Yea factory and make sure to get a catch can of some sort. You can make one from a air compressor line air drier... or buy one of the like. http://www.accmachtech.com/catchcans.asp
Gray97
Kansas
Grayston
327, TH350
The catch can looks pretty sweet and looks like it could almost fit where my gas vapor can used to be.
350runner
tx
Ceasar
Yup. I put one on my 2000 Durango and it was amazing to see how much oil vapor builds up in there.
Gray97
Kansas
Grayston
327, TH350
I never thought about oil vapor occuring.
350runner
tx
Ceasar
Yea try putting a cheap one on a old 350...you'll see what I'm talkin bout. Even that air line drier will do the same. Just have to put a container of some sort under to contain the oil vapor
Gray97
Kansas
Grayston
327, TH350
Got one but it's blowing oil from the hole in the pan too.
350runner
tx
Ceasar
Dang.
Gray97
Kansas
Grayston
327, TH350
It was pretty nice, except for bad assembly.
ExtraZ
