2 vs 3 v- groove power steering pulley
Sgt Gus
Mark
R20 3/4 ton
454ci/7.4L
So the '87 3/4 ton, 454 has a 3-groove power steering pulley. NOT coming off.
Will a 2-groove for the saginaw work and line up? The back v-grooves are approx 5.75" diameter. BThis truck was not using the front smaller v-groove 5.125 diameter?
Press on, remote reservoir, new one on the way.
Now I need to order a pulley.
ali_c20
Austria
Alexander
C20, K5
Sgt Gus
Mark
R20 3/4 ton
454ci/7.4L
Do you have a pulley puller tool ?
Which groove of the crank pulley was used ?
Rockauto shows a single and double groove pulley for your truck.
https://www.rockauto.com/en/moreinfo.php?pk=12729793&cc=1059982&pt=7381&jsn=990
https://www.rockauto.com/en/moreinfo.php?pk=12729797&cc=1059982&pt=7381&jsn=989
I would wait for the new pump, test mount and look how everything lines up.
Yes on puller, used PB and even torch. Tore the lip, once it started, no hope, but I tried.
Yes! Rockauto has. Pump was a 12541, but Lares didn't show a pulley on their website. But there it be on Rockauto. Called them just to verify. #159 They are very (Lares) helpful.
Thanks for your help! So much time researching crap...
Sgt Gus
Mark
R20 3/4 ton
454ci/7.4L
Ours was 3-groove but front smaller not used. So using the 2 v-groove pulley.
Not sure it applies to every year, but on my ‘75 there are two choices for the PS belt. And I think that is why you have a 3 groove pulley.
The longer PS belt, which was the HD cooling option, goes around the PS, crankshaft and the water pump. If the alternator belt breaks, you will still have the PS belt driving the water pump. No overheating if the alternator belt is broken or slipping.
The shorter PS belt just goes around the crankshaft and the PS pulley.
depending on engine and setup, the extra ps pump pulley slot powered some compressors (larger groove) or SMOG pumps (small groove)
Sgt Gus
Mark
R20 3/4 ton
454ci/7.4L
I bet for smog. The 87 has/had one on passenger side below the alternator. I believe 88 had two. One on each side.
Ours has a six groove serpentine from alternator, (smog), water pump to crank. Single v-groove from crank to power steering. 2nd single v-groove from crank, water pump, power steering, and AC compressor.
Sgt Gus
Mark
R20 3/4 ton
454ci/7.4L
Also, yesterday I realized I need the bracket off the old PS pump that the pulley didn't come off...PB, torch, Yada Yada. Got one bolt off, the 2nd...?! Well, "I fought the bolt and the hacksaw won"; repeat for triumphant song in my head! So not likely beable to repair old one for a spare.
ali_c20
Austria
Alexander
C20, K5
One stubborn bolt can mess up a lot....and drive one to the edge off insanity.
Sgt Gus
Mark
R20 3/4 ton
454ci/7.4L
Also figured out all the bolts are metric. M10x1.5, 20-25mm. Went to depot (while thinking about legomatic saying get a Irwin measuring tool) and used their on the wall dohicky to figure out and got two bolts. (Despite internet saying 3/8"-16) Cleaned and painted last night along with previous stud and bolt cap from the other. Those I couldn't remove until I just grabbed the air gun. Zip
Baking in the oven this morning. Still waiting on pressure side hose that keeps being delayed.
Staying on the happy side of sanity. ;)
Sgt Gus
Mark
R20 3/4 ton
454ci/7.4L
Should I put a little anti-seize on the shaft before I put the pully on, or lithium greese?
legopnuematic
Licensed Junk Dealer
MO
Spencer
Either should be ok, something with Molybdenum Disulfide would be best.
Be sure the pulley bore is clean and clear of any paint or coatings.
Sgt Gus
Mark
R20 3/4 ton
454ci/7.4L
Damn, Lares pump reservoir tube diameter is 5/8"! Both old and new reservoir are 3/4"! WTF. What now?
Sgt Gus
Mark
R20 3/4 ton
454ci/7.4L
Lithium grease and made it happen with some 5/8" hose. Gonna loose my sh*t over a power steering pump. :Stupid Me:
chevelless07
