82sbshortbed
Fuckemall!!
- Mar 1, 2018
- SE Texas
- Doug
- 1500 shortbed, 1500 longbed
Ok, I'm looking for a radiator upgrade for my square. 454 with no fan shroud in it right now is not good. I have a perfectly good fan shroud that came out when swapped out the 305. It's too big for the 454.
It looks like I'll be going aluminum with electric fans. Then I can remove the fan on it now(that's really not doing any good at a stop) and take a little load off the motor.
I called American radiator yesterday and talked to the guy about it. I asked if he had a 4 core that would fit. I even said a 3 core would probably work too. He said he had a 2 core that would fit it.
I said a 2 core? It's a bbc and I think that's too small. He then told me his are 1" tubes where most are 1/2" tubes. So it should cool better with the bigger tubes. So 4 1/2"(or 3) vs 2 1" tubes.
I've never heard if this. Does anyone know anything about this?
What radiator are you using for your BBC?
I'm figuring anything with fans to keep the air flowing will be better than what I have. Also he quoted me 400 bucks. I've seen them cheaper but, don't want a cheaper one that I won't be happy with.
Any information on this will be appreciated. I don't mind spending money for something good that will last either.
