1g80 locking differential
DesertBob
Goodlettsville, TN
Bob
350M/LT9
My 1985 K20 has an RPO Code 1G80 Locking Differential in the 14bolt SF rear axle. Is this any good? Anything special I need to do when I change the gear oil?
Thanks
Swims350
Logan WV
none
it's not great but being a 14 bolt it's alot stronger then the 10 bolt versions, the 10 bolts are known as gov bomb, instead of gov lock. Basically when it spins , it throw the weights and locks in both wheels, almost like positrac.
I would use the limited slip differential oil only, or at least get the additive to go in the reg. gear oil for it.
Camo
mobile
1500 extended cab 4x4
4.8 V8
G80 is referred to as a GOV BOMB for a reason. If you dont off road it, you should be fin< but they are not trail rated.
Use the additive for limited slip differentials.
Obullard74
