1999 Saturn sl2
I really enjoy all these threads. You should just flip cars and document them like this.
Mackadocious916
Sacramento
Steve
82 c10, 85 k20
GM
Diesel to gas swap
Thanks...
Id love too flip, but feel guilty/ toouxh consciouss if not 100% so usually lose $$$... My neighbor down the street I sold last two to tercel $600, and $1700 for tracker, he got $900 and a north star caddy trade, and 2400 so he has that magic...smh...
But I think I'll have these builds for a while....saturn, tacoma, and document whatever happens to f smog...
Mackadocious916
Sacramento
Steve
82 c10, 85 k20
GM
Diesel to gas swap
Surfin the web, saw this and it kinda motivated me to go from browsin 17"s to 18"s....
Researching the upsizing....
How she sits now with 15"s up front and 16"s out back....
Saw this on offer up...
Mackadocious916
Sacramento
Steve
82 c10, 85 k20
GM
Diesel to gas swap
Went and checked them out...
Pretty decent tread...surpirsed...
Talked her down to $160.... The prius gets it done again...
Got dark. Will install attempt tommorrow... Hopefully dont need hub rings or et/acorn special lugs, and can just bolt on and go...
Mackadocious916
Sacramento
Steve
82 c10, 85 k20
GM
Diesel to gas swap
The wheelfairy came....
Mackadocious916
Sacramento
Steve
82 c10, 85 k20
GM
Diesel to gas swap
Mackadocious916
Sacramento
Steve
82 c10, 85 k20
GM
Diesel to gas swap
My dad said the sunroof leaked....so I put a dropcloth over her... Thought id have all summer to fix, but random thunderstorm coming madee do the wheel swap at night...
Before...
Dark after...
Will take some pics tommorrow...
Mackadocious916
Sacramento
Steve
82 c10, 85 k20
GM
Diesel to gas swap
Caught some overcast pics between showers....
Mackadocious916
Sacramento
Steve
82 c10, 85 k20
GM
Diesel to gas swap
Went out to work on the interior floor...
just used two different cans you get at the autostore with brush built into the end you can remove, but I scrubed with dish scrubber for about an hour all around ....heavy coats of the spray and elbow grease.... She could probly use some moe rpunds, or an extractor, but saw some progress....
Front driver before
After
Front pass before
After
Mackadocious916
Sacramento
Steve
82 c10, 85 k20
GM
Diesel to gas swap
Rear drivers before...
After
Back
Before
After
Mackadocious916
Sacramento
Steve
82 c10, 85 k20
GM
Diesel to gas swap
Took her on a quick trip to feel the wheels out and they roll smooth hit the sunroofI close button and it closed a little more...seemingly sealed and not a issue leaking anymore....
Mackadocious916
Sacramento
Steve
82 c10, 85 k20
GM
Diesel to gas swap
Mackadocious916
Sacramento
Steve
82 c10, 85 k20
GM
Diesel to gas swap
So I powered through after work. Took about 4-5 hours with breaks... Mindblown how saturns have removable skins. Never seen it before.
Mackadocious916
Sacramento
Steve
82 c10, 85 k20
GM
Diesel to gas swap
The plastic on the track looked okay
But it was really cracked
Allowing this to slip out only rolling down like 35%
Found main window switch has rear pass out, so reversed it to get the window up, and will order one 4in1 switch.. The just turn signals/ wiper switch
Mackadocious916
Sacramento
Steve
82 c10, 85 k20
GM
Diesel to gas swap
So I went out to try and fix why no turn signals... This was the project I avoided on mini me when I put the lift on and instructions said I had to put spacer in (but I dont think it was necessary) near rag joint which caused steering wheel to be off and when I fixed it, the clockspring was broke... So I tried to take my rime and avoid abs light no horn in this car....
So I got her all back together, the turn signals and wipers work, but abs light is on....:manos:.... I hate these clocksprings...
I will try fuses to see if it resets as I dont want to pick n pull this piece...
The only other issue is master window switch I just ordered off ebay...
And the horn/ but may be clockspring
ben_swager
