SirRobyn0
- Dec 6, 2019
- In the woods in Western Washington
- C20
Well I'm just posting this for anyone that is interested. @idahovette I thought you might be interested in seeing the paperwork for this one.
(UPDATE: this thread is going on about other stuff on the Jeep as well)
Anyhow, so long story short I own a 1996 Grand Cherokee 5.2L limited. We've had it for around 10 years or so. Last fall it developed a little bit of a whine in the transmission which progressed to being quite loud fairly quickly. Noise was heard at a stop in drive or reverse, but as you'd speed up the noise would quite down before it shifted. My transmission builder suspected that the whine was coming from the converter but because it had 275K on it, and I'd pulled the pan and found copious amounts of brass in it, he said it's time for a rebuild.
So I pulled it out week before last and got it back at the end of last week. I've been slowly getting back in and should be taking it for a test drive on my lunch today.
He said there was obvious signs metal had circulated though the system and it was basically just worn out any way. Here's the slip if anyone is interested. Keep in mind I'm living in one of the most expensive parts of the country, it's pretty likely it would be cheaper where most of you are.
