1989 Suburban Fan Shroud
My dads 75 has a 19 inch with AC rad HD cooling and all, it has the center plate that holds it to core support that is flat, but the shroud setup is a two piece, kinda. it has one that goes on the rad, but then there is like an "upper" part that reaches back further from the main part I think primarily for hand safety around the fan but that is a 75 too,not a 81+ and older at that. not sure how common. I have a 19 inch rad I want to put in but I dont have a fan shroud for that either(my 2 piece is broken but i dont feel like reusing anyway)
Dave
Suburban
Fixed it!
The LMC shroud didn’t fit well, but could have been made to work. The NOS GM shroud fit pretty good, but I did add an extra screw to make sure the top and bottom half stay together.
This forum helped me so much! Thanks to you all!
Dave
Suburban
Here is detail of the extra screw, I put one just like it on the right side, too.
am i the only one who had staples all over my god damn connection between them(one visible on right)
shannonhalsey
