- May 13, 2019
- Oregon
- Eric
- K25
- 350-4bbl
This has been discussed a bunch of times. The oil pressure switch on the TBI's is only to keep the fuel pump going if the relay fails while the engine is running. This is why a relay failure will never cause the engine to die while driving. You always get to your destination, shut it off, and then get a no-start on the next attempt. A failed oil pressure switch will only cause the fuel pump to not run IF the relay is also bad.As far as I know on both the carb and TBI engines there are 2 oil ports, one by the filter and one by the distributor. Carbed engines used the one by the distributor, TBI used the one by the oil filter. Some engines used both.
So the way the fuel pump works is though a relay. Just like Andrew said the system is back up not permissive. As I understand it the principle is so if the engine stalls and the key is on the fuel pump is off. I believe the main reason is so if there were an accident and the driver is unable to turn the key off the pump does dump 20 gallons of fuel on the ground. If there were a problem in this system your engine would not run, if I were you I'd scratch it off the list.
Its also why running your oil low will still blow up your engine on a TBI motor... zero oil pressure will NOT shut the engine off(at least not until it starts shedding parts)
