1986 ECM control torque convertor lockup?
mavtricks71
az
mike
I have an 1986 K10 California emissions crap. Does anybody know if the ECM controls the torque convertor lockup? It is the horrible year that has the electronic Carberator. Also has cruise control. thank you
Jgonick
West Texas
Joel
Look at the wires coming out of the transmission-(700r4) If one of them is Purple I believe it uses the ECM.
1st image is ECM & 2nd image is without
Vbb199
B-rate Hillbilly Customs
Salisbury NC
Vince
89 Suburban R1500, 79 C10
Its either that, or Manifold Vacuum referenced lockup.
mavtricks71
az
mike
Thanks for replies ill look into it. !!!
RanchWelder
Earth
Blazer
350ci
One wire goes to ground, the other to the break switch.
Add a ground and see if it works?
seanhatesregister
