1985 K20. Need inspection to get tags. How to wire external horn button?
Nasty-LSX
TogetherforeverCovid19
HOUSTON TX
Mi Hung Lo
c10/k10/k20
LSX
My horn does not work. Im going to wire in a small horn button. What is the best easiest way to wire it up
without running a wire all the way to the horn?
Anyone know the horn wire color running into the column? How have you done it. Thanks :happy160:
brooksman9
Olive Branch, MS
Patrick
Silverado & Custom Deluxe
350 & 305
All you need to do is run a ground through the button to the horn relay under the dash. I think it is mounted on a courtesy plate or something like that. Two relays above the gas pedal. Just have to find the right wire.
brooksman9
Olive Branch, MS
Patrick
350 & 305
Convenience center relay. That’s it
brooksman9
Olive Branch, MS
Patrick
350 & 305
Matt69olds
Central Indiana
GMC 1/2 ton
455 Olds
The ground trigger in the column is a black wire.
Start at the relay in the convenience center. Unplug it, test for power on the orange wire. If you have power, use a fused jumper wire to jump power from the orange wire to the dark green, the horn should sound. Next, test for continuity from the black wire of the horn relay to ground while pressing the horn button. No continuity, means either a wiring issue in the column or someone has taken the column apart and omitted a few parts.
WFO
Texas Panhandle
Probably not your issue, but when I bought my truck, the horn didn't work.
Pulled the horn cover off the steering wheel just to look around.
Pulled the horn button out, stretched the spring a little and put it back in and it worked.
Never got around to getting a new spring, but it's still working after 7 years.
Nasty-LSX
HOUSTON TX
Mi Hung Lo
c10/k10/k20
LSX
Ok thanks for all the info. I will mess with it tonite.
I forgot to say when I hit the horn button my horn
relay buzzes. Could I have a bad relay? If I test it like Matt69
says and it works, then I should Have a bad relay?
Jgonick
West Texas
Joel
here is a visual of the convenience center. As stated above. ground black wire to complete circuit to relay. Relay gives power to dark green to horn.
yes, could be bad relay.
WebMonkey
Missouri Ozarks
the terminals on the horn itself were funky on my 85 k20 super double xtra heavy duty.
scuffed them up shiny and horn honks fine right.
good luck
'monkey
we call that a FUSE PANEL in AMERICA. speak english or LEAVE.
Nasty-LSX
HOUSTON TX
Mi Hung Lo
c10/k10/k20
LSX
This is were I feel stupid. I was going to try everything else before checking to
see if there was a fuse in the panel.
YEA, THE FUSE WAS MISSING. I feel so retarded :insane: It works fine now!
Jgonick
West Texas
Joel
Somewhere around 85 I think, they added separate fuse panel called the convenience center.
apparently squares had more than ONE auxillary fuse box and the one pictured is above the gas pedal
This is just gross. nice auxillary fuse box
dannyphx
