1985 C20: Power to cab, will not start when key is in "on" position
1985C20FLATBED
CT
sam
Hello All,
Recently acquired a 1985 Chevy C20 w/ a 350 and its Automatic. Truck is completely stock outside of some extra work lights installed by previous owners. When I turn the key the cab has power, buzzer goes off, dash lights on, etc. When I turn the key to the on position nothing happens. Truck worked fine until one day it didn't. It has a new battery and the fusible link is new. Looking for some guidance, I've heard ignition switch or neutral safety switch would be a good start but would like some advice prior to getting into it. Thanks
legopnuematic
Licensed Junk Dealer
MO
Spencer
Is it a tilt column?
Carb'ed Vortec 350
Yeah, neutral safety switch would be a good place to start.
Sad Sack
Omaha, NE
Bryan
C15
Does it start / turn over with a remote starter switch employed?
:welcome:
Sad Sack
Omaha, NE
Bryan
C15
Should I try that before the ignition switch?
One can always perform that with a screwdriver as a backup. Basically you're bypassing the ignition switch which should tell you a couple things if starter does or doesn't engage.
legopnuematic
MO
Spencer
The neutral safety witch on these trucks (automatics) are on the steering column, sometimes they get can get out of adjustment for various reasons. They should allow the truck to be started in park or neutral, with your foot in the brake you can hold the key in the start position and pull the gear lever from park and down past neutral, if it cranks at some point doing that then the NSS is worn or out of adjustment.
83Stepper
Massachusetts
Chad
Could be a lot of different things. Neutral Safety Switch, Ignition switch, bad ground, bad starter etc.
Start with making sure the starter is good. Enlist the help of a buddy to make sure that when the key is turned to the start position, you get power to the solenoid. If no power at the solenoid, then more than likely it's the ignition switch or neutral safety switch. You can also test this with a remote push button start switch. If you have power at the solenoid and it's not spinning, then starter is no good. Can also be verified with a remote start button.
von5814
