1985 c20 Distributor Issue
r.booser
Knoxville
Ron
New member and recently purchased my first square body 350 c20. I have wanted one for a while so let the work begin. I purchased this vehicle for a good price knowing the it needs some work. After changing the thermostat, plugs and wires I was able to get her fired up. Since this is my first I'm not a master mechanic I was hoping for some pointers. It was about 10 degrees out and she wouldn't start. Would roll over but nothing. Now the other day when I had it running I would shut it off, come back 30 minutes later and it would fire right up (it was in the 50's). I was going to change the cap and rotor but it seems the problem might be the ignition coil also. But my question is should I just replace the whole distributor? That way I have all new internals. If so any suggestions? I don't want to waste money but I also want everything to run well.
Stroked
Beloit, Kansas
Jared
First off, welcome to GMSB!
As to your question, I'm no master mechanic either by any means. But if you have the money, I would get a new distributor. The bushings can get worn in old ones and cause all sorts of grief. Not to mention that by the time you replace all the internals, you'll be halfway to a new one anyway.
r.booser
Knoxville
Ron
That is what I was leaning towards just wanted some opinions. Do you have any suggestions? Or what not to purchase?
Stroked
Beloit, Kansas
Jared
I've only ever used the stock GM HEI, but I've heard good things about MSD distributors. A lot of people seem to like the Summit Racing brand dist as well.
GTME94
Metro Detroit/Holland, MI
Terry
C2500 C6P Camper Special
454/TH400/14bff 3.73
This may seem like a silly question but I'm assuming its carbureted and that you know to set the choke? Maybe the choke needs to be adjusted?
My choke still isn't right but it will at least start up when cold.
I only ask that questions because some younger folks learned to drive with newer vehicles that have all been fuel injected of some sort and never learned to mash the pedal twice before starting up a car with a carburetor.
r.booser
Knoxville
Ron
Thanks for the help guys! Yes I do pump the gas and sadly that isn't a silly question. I know plenty of people that have no idea hot to change their own oil let alone something that simple. Thanks for the ebay link, they are just an hour down the road so hopefully I'll have that tomorrow. That is a steal for a OEM spec distributor. Any other suggestions would be great. Can't wait to fix this thing up!
John81287
Mchenry,IL
V20
1985 c20
This only works with a mech fuel pump. If your truck is crossbreed like mine I have a carb with a electric fuel pump. Mashing the pedal doesn't do much for mine.
r.booser
Knoxville
Ron
it is not electronic yet. But I'm thinking about adding that once I get it up and running properly.
GTME94
Terry
Mashing the pedal gives a couple of squirts from the accelerator pump, should help regardless of what type of fuel pump. Since a carb relies on vacuum to get fuel flowing instead of a pressurized spray from injectors that is important to get some fuel into the intake during low vacuum cranking.
That's right. If it's carbed, manual or electric pump doesn't matter. You still have to pump it for the accelerator pump to some fuel in the throat of the carb and to set the choke too if you have auto choke.
If you're not getting much help from pumping the gas John, you might have weak acceleator pump in the carb. When it goes completely, you'll know it when you take from a light and it stalls.
Welcome to GMSB Ron. C20's are one of my favorite models. I like the ride and the stance.
I agree with 89Suburban, you might look into one of those $50 Skip White distrubutors on eBay. They are China made Pro Form, but work well so far. I'm using 2 of them myself. You can hardley get a cap and rotor for that price these days.
r.booser
Knoxville
Ron
purchased one and threw it in. After doing it 180 degrees off and fixing it we are finally up and running. Now time to hook back up the heater coil and hope she doesn't leak!
180 degrees out... That's called experience. Seems everyone has to go through that at least once before they get it right. :lol:
r.booser
Knoxville
Ron
well trust me, lesson learned.
goodwrenchca
