1978 C10 front marker lights
My78truck
'Ol Holly
Virginia
Becky
C10 Silverado
5.7L
I don't have pics of the housings not mounted, but these are the full housing led conversions. That plug and played like factory bulbs.
Hey PrairieDrifter - these LMC ones work correctly with lights on or off right?
PrairieDrifter
North Dakota
Mason
84,79,77,76,70,48
350, 350, 350, 350, 350, 350
Yes sir I threw them in right after removing the led bulbs. Worked the exact same. I will note that I'm not always the biggest fan of lmc, as they usually kill you on shipping and some prices, and not all items are quality. But their led lights and quite a few other items are pretty nice pieces.
My78truck
'Ol Holly
Virginia
Becky
C10 Silverado
5.7L
Hey PrairieDrifter - Received my LMC order today with my markers. GUESS WHAT!!!!!! They are EXACTLY like the ones I just returned to carID!!!! WTF!!!! Apparently Union Pacific is the only company that makes these. Again, no instructions. So, I am going to cut my socket, connect black to black, blue to red and use wire nuts for a temp check. IF!!!! everything works as it should. I will use low temp weld/heat shrink butt connectors to make a permanent fix.
PrairieDrifter
North Dakota
Mason
84,79,77,76,70,48
I ordered them from LMC, I think 2 weeks after they came out with them. Maybe they switched it? Or maybe this is all the from the difference of my truck being an 84. I am 100% certain mine are plug and play.
Which doesn't make sense in the first place, as the light housings are the only thing different, the wiring plugs are the same.
I would like to apologize for sending you on a little bit of a goose chase. Both my tail lights and marker lights from LMC were plug and play, so I'm pretty baffled that the one led set out of like 4 or 5 doesn't plug and play. I even had led markers and tails on my 70 c10 (lmc lights) they were plug and play and worked great too!
If I were you, I would see if you could find a pigtail that will connect to the trucks existing connector then you can just attach you wire leads to the pig tail, to make it your own plug and play system. Instead of cutting off your plug, and hardwiring. Either way will work fine. I would rather have a disconnect point there.
My78truck
'Ol Holly
Virginia
Becky
C10 Silverado
5.7L
Hey, not a problem. Just my luck that they do not have the plug.......even though I looked again and I saw a plug. I also looked at another sight, had the same lights, and they also showed a plug. But I am sure if I ordered them, they would be the same. So, where can I find a connector, or as you call it a pigtail, that I can plug into my existing plug? I really do not want to cut my wiring, but I am running out of options. These are the last 2 lights to go LED. The rest are working fine.
PrairieDrifter
North Dakota
Mason
84,79,77,76,70,48
That was my thought as well, all the pictures show the plugs.... I searched for a "194/168 MALE pigtail connector". Found some right away, you'll just have to either take a shot on some cheaper ones or maybe spend a little extra.
Here's some, I've never ordered any so I can't recommend any. As long as the plug looks decent and the wires are heavy enough, it shouldn't be a problem.
https://www.amazon.com/YSY-Headlight-Assembly-Extended-Connector/dp/B07WTZMNZL
My78truck
'Ol Holly
Virginia
Becky
C10 Silverado
5.7L
THANK YOU!!!!! I do not care what it costs, I just want it to work and not have to cut my wiring. The ones you sent link for is for 2 which is PERFECT!!!! Thanks for helping me. I will let you know how it goes.
My78truck
'Ol Holly
Virginia
Becky
C10 Silverado
5.7L
Okay PrairieDrifter - I received my pigtails today. Went out, stripped both sets of wires back about 1/2 inch, wirenut them together and grounded the light on a screw connector. Turned on ignition (did not start truck). Lights off, both the directional under headlights and turn signal blinked. Pulled headlights on - directional under headlights blinked, new side markers did not. :( Started truck, still no blink. :( Decided I would unplug the headlights and see if the signals would work. Lights off, worked, lights pulled on WORKED!!!!!! :pepper:Hmmmmmmm, plugged in headlight, STILL WORKING!!!!:party36: Turned off signal and lights. Waited a few second and tried again!!! Works!!!!! :party36::pepper::party36::pepper::party36::pepper:
THANK YOU!!! for suggesting the pigtails!!! I now just need to cut back the wire on the light (because the red wire is over 1 ft long but not the black) and splice them together using my low heat solder/heat shrink connectors. So glad I do not need to cut my original sockets off.
PrairieDrifter
North Dakota
Mason
84,79,77,76,70,48
No worries! Just shorten up those pigtails pretty short, not too short. The ones I've got have a little extra length so you're not trying to squeeze your hand in there, to plug the damn things in.
Glad you got it figured out! Sounds like you might have some corrosion or connection issues? If you unplugged the headlights, then the sidemarkers started working fine, then even after you plugged the headlights back in. Sounds to me like you either have a wire that may have internal damage, or you're having connection issues at some connectors.
I would go around your light connectors and inspect and clean them with electrical connector cleaner, then maybe a dab of di-electric grease.
oldretiredafguy
N. Texas
1988, 1988, 1991, 1983
350, 350, 350, 350
Hmmmm.... i have LEDs in my cluster and dome but the outside lights wouldnt agree so i gave up. Im sorry, maybe someone a lil more electrical knowledgable can input help here.
Don't f**k with Mother Nature.
My78truck
'Ol Holly
Virginia
Becky
C10 Silverado
5.7L
Well, all is not happy.......I spoke too soon. Back to old problem. BUT!!!! here is a new quirk. I plugged in the marker to the passenger side, hit the lights and it all works as it should. W.....T......F........ I am so over this. Contacted company I bought headlights from. They are saying resistors will help. UUUGGGGHHHH!!!!!!!! Can I pass an inspection without the markers blinking when the headlights are on???? They will be lit up just not blink when headlights are on.
gotyourgoat
NRV Virginia
gotyourgoat
smokin' 305
Technically no, I don't think that would fly. The guy is going to pull the knob for the lights and then check blinkers.
A lot of places won't even let you in the garage area for inspections. The usual deal is two guys verify the outside lights, one inside and one outside. Then they check the engine bay and everything underneath.
I have been going to the same place for years. I do hang out with the truck and we ******** about cars while he picks over ol brown. The state likes to screw over inspection places so they have become more thorough.
If you could manipulate the situation and be the one to operate the lights yourself. Showing the blinkers work first and then hit the headlights. You might be able to get a pass but you still wouldn't have working lights with the headlights on apparently.
:33:
Your issues are part of the reason why I haven't gone led. That and the lights and the ignition are the only things electrical on ol brown...it's far from a stressed system.
sirweesarunch
Oceanside
Isn’t there a special flasher relay for led lights ?
jonahhouse
